Author Topic: Painting. Do I do more or leave it?  (Read 2007 times)
anewcomb
  • Last login:July 08, 2008, 01:38:27 pm
    • the_source
« on: May 01, 2008, 09:50:03 pm »
I need some advice on what to do next (if anything) for my cabinet finish. Here is what I have done so far ...
1) Filled and sanded any screw/nail holes.
2) Applied 2 coats of tinted latex primer (something called ZAP from Lowes) thinned with Flotrol.
3) Sanded smooth with 220 grit sandpaper.
4) Applied 3 coats of black semi-gloss latex paint thinned with Flotrol.
I used a low volume sprayer attachment (found at Harbor Freight Tools) with my small compressor. It seems to work alright, but I have never used a sprayer like this before. The cabinet looks alright from a distance, but when you are up close and the light is shining on it it looks like this (see attached image).
The question I have is should I live with the finish the way it is, or is there a way to even out the finish without applying another coat?
Thanks,
Aaron Newcomb
http://www.thesourceshow.org
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: Painting. Do I do more or leave it?
« Reply #1 on: May 01, 2008, 10:06:02 pm »
I've always rolled on the paint.  To spray it on definently requires a steady hand.  Looks like it was too thick when it was sprayed on.
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
boogieman
  • Last login:January 19, 2019, 05:35:48 pm
  • advancedspuds.com
    • advancedspuds - your source for spudgun information
« Reply #2 on: May 01, 2008, 10:38:15 pm »
Not sure on cabinets, but I know on other stuff, if you get an orange peel finish like that, you can sand it with fine paper till it's smooth then give it another coat of paint.  I know on motorcycle stuff  you can wet sand, not sure on wood.
WunderCade
« Reply #3 on: May 01, 2008, 10:39:07 pm »
It looks like you didn't sand it really smooth BEFORE applying the primer. Is that the case?
anewcomb
    • the_source
« Reply #4 on: May 01, 2008, 10:41:43 pm »
Yeah. I thought it was too thick when it was going on, but since I had never used one before I wasn't sure. I did some tests before I started, but I got too antsy and just went for it. I have some wet sanding paper that I thought I might try once the paint cures, but I would like to avoid doing another top coat.
I did sand the primer very well (but not through to the wood) before I started the top coat.
Thanks,
Aaron Newcomb
anewcomb
    • the_source
« Reply #5 on: May 01, 2008, 10:43:41 pm »
Yeah I did sand smooth before the primer as well. :(
Thanks,
Aaron Newcomb
WunderCade
« Reply #6 on: May 02, 2008, 01:44:27 am »
Here's a couple tutorials I found helpful:
Tutorial 1
Tutorial 2
anewcomb
    • the_source
« Reply #7 on: May 02, 2008, 09:21:53 am »
Thanks Wunder. I have read each of these a couple of times. They are both going for a mirror finish which I am not. However, I noticed this time in the PC Case tutorial that he does not apply any lacquer and just wet sands and buffs the paint directly after it has cured for a few weeks. This tells me that it is possible for me to do this as well. I think I will wait a few weeks and give it a try on the back of the cabinet to see how it comes out. I will post anther picture with the result. Thanks for making me look at these another time!
Thanks,
Aaron Newcomb
Ummon
  • Trade Count: (+13)
« Reply #8 on: May 03, 2008, 02:44:20 pm »
Or you could leave it that way. Has character.
Yo. Chocolate.
Stephen Hawking
Jdurg
« Reply #9 on: May 03, 2008, 02:48:19 pm »
That's not a bad idea either.  On my CP, I put on a bunch of coats of paint and it had a bit of a rough look to it.  I then sanded it down, and in some spots the paint chipped away back to the primer/wood.  Not a HUGE spot, but a tiny little nick.  I was thinking about re-painting it, but now that the artwork is on the CP kind of has some used character to it that I really like.  I think I might purposely scratch areas of it to make it look like it's been used.  I think as a whole those of us in this hobby try too much to create pristine, brand new looking cabs.  Real machines have character and signs of use, and that's what I'm trying to go for.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
