Author Topic: A N00B To JAMMA Needs Assistance  (Read 3621 times)
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« on: March 27, 2008, 04:23:47 pm »
Ok,
I know there are a lot of experienced people out here that can help me with this. I want to build a JAMMA machine where I can swap boards etc and have different games. Eventually I want a NAOMI system with GD-ROM drive but for right now all I have is Blitz99 On the way to me. what all do I need o get started? and how do the controls get wired? I have extensive experience with wiring up Mame control panels but this is new.
If You Are Going To Meddle At Least Listen
spacies
Re: A N00B To JAMMA Needs Assistance
« Reply #1 on: March 27, 2008, 08:14:26 pm »
Google 'jamma pinouts'
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
« Reply #2 on: March 27, 2008, 10:05:07 pm »
DJ Infinity
« Reply #3 on: March 27, 2008, 10:37:35 pm »
Thank you. I will study these things  :cheers:
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #4 on: March 28, 2008, 08:08:45 pm »
You'll have to get a video encoder to convert the cga to composite or whatever.  That is unless you have an arcade monitor or a monitor that can display cga.  The naomi runs at 31hz so you can just use a pc monitor for that.
DJ Infinity
« Reply #5 on: March 28, 2008, 08:20:44 pm »
The NAOMI is a want. But thanx for the info. what I have on the way is Blitz99. I did buy a video converter cause at the time of this posting all I have are LCD's I don't have a CGA monitor anywhere. I am going to the amusement auction tomorrow, I hope I can snag a decnt cab with monitor to put blitz99 in.
TheDriver
  • Last login:December 21, 2008, 04:08:37 pm
« Reply #6 on: April 08, 2008, 09:15:23 am »
Can I ask what converter you got?
Regards.
Level42
DJ Infinity
« Reply #8 on: April 08, 2008, 07:09:32 pm »
Regards.
Hmm I can't find the seller on ebay anymore. It was like $92.00. I havent tested it yet.
DJ Infinity
« Reply #9 on: April 17, 2008, 10:19:42 am »
This for the power:
http://therealbobroberts.net/acwiring.html
This for the Jamma wiring:
http://www.jammaboards.com/jcenter_jamma_pinout.html
Ok, I am beginning my project today can someone help me out with wiring? The one on the realbobroberts is kinda outdated for what I am doing. I do not need an isolation transformer in the equasion. My monitor plugs directly into a socket. Any help would be greatly appreciated.
Bleagh
    • BLEAGH!
« Reply #10 on: April 17, 2008, 02:11:33 pm »
Just leave the isolation transformer out and the rest stays the same.
What kind of power supply do you have?
DJ Infinity
« Reply #11 on: April 17, 2008, 03:25:03 pm »
The Black Happs one. I was told also the inline fuse is not needed. Can someone put it in dummy terms. Step 1 do this etc. and give me a pic I could zoom in on or at least one I can see clearly. Thanx  :cheers:
« Last Edit: April 17, 2008, 06:52:44 pm by DJ Infinity »
Bleagh
    • BLEAGH!
« Reply #12 on: April 17, 2008, 09:31:17 pm »
If you want you can just put the field ground from the plug straight to fg on the power supply, and the other two on the ac/l and ac/n  it doesnt matter which one goes on l or n as just make sure the ground (the big round pin on the bottom of the plug) goes to FG.  and it will work.
http://www.bleagh.com/basic-ac.gif
not the best way to do it, but it will work.
DJ Infinity
« Reply #13 on: April 17, 2008, 10:08:41 pm »
That much I gathered looking at my Blitz cab. Ok can you show me where the on off switch get wired to please? thank you  :cheers:
Bleagh
    • BLEAGH!
« Reply #14 on: April 18, 2008, 11:33:36 am »
you can put a switch on either ac line, or both.
DJ Infinity
« Reply #15 on: April 18, 2008, 12:10:38 pm »
So lemme get this str8 (you know I'm a lil slow) the on off switch can be wired to the same spot as the ac lines? Do I need 3 wires for it aswell or just two? Thank you for helping me  :cheers:
Bleagh
    • BLEAGH!
« Reply #16 on: April 18, 2008, 12:20:08 pm »
Something like this will work.
http://www.bleagh.com/switch-ac.gif
DJ Infinity
« Reply #17 on: April 18, 2008, 12:25:59 pm »
Thank you!
so that other block that Bob Roberts had I guess acts as a splitter? so you could split off ac to the marquee correct? One more question and I think I have it. What gauge wire does one use for this? The guy at radio shack looked at me all goofy when I asked what gauge wire do you use for AC wiring.
TheDriver
« Reply #18 on: April 18, 2008, 01:27:24 pm »
18 gauge wire should be fine, that's what I used. :)
