Author Topic: Help! 29" Sharp Image Monitor Acts Dead!  (Read 1334 times)
hokey1
  • Last login:November 20, 2017, 07:54:45 pm
« on: March 18, 2008, 03:25:55 pm »
    Well my 29" Sharp Image crt monitor went black right in the middle of pacman :hissy:.   I tried all the usual stuff (hooked up a different monitor  and it worked fine. ) Windows acts like it is there, when I hook up two monitors(the sharp image and, an lcd) windows "sees" 2 monitors.    I tried changing the rez and so forth but the  screen stays black, It is black during boot-up also.  Is it worth fixing?  Is there anything else I can try?  Finding someone to work on Crt's these days is harder than finding an encyclopedia salesman.  (indianapolis area)  Is it time to move on and say goodbye?
grantspain
Re: Help! 29" Sharp Image Monitor Acts Dead!
« Reply #1 on: March 18, 2008, 04:05:23 pm »
do you feel static on the tube?
does the screen flash when you turn the power off?
can you see an orange glow from the neck?
have you turned up the screen volts to see if you get any type of picture?
hokey1
« Reply #2 on: March 19, 2008, 12:22:51 am »
No static
No flash
No glow
I do not know what screen volts are :-[
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 19, 2008, 12:55:14 pm »
Look in the telephone directory Yellow Pages under the heading of "Amusement Devices" for a distributor or game operator. Many will have a service department where you can take your monitor to get repaired.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: March 19, 2008, 11:01:00 pm »
Pm , can likely set u up with a couple of TV guys in Indy .
remember monitors are similar to a tv .  just no tuner /audio circuits to mess with ....
qrz
« Last Edit: March 21, 2008, 10:47:56 pm by qrz »
