Author Topic: Where to buy a 3" clear trackball  (Read 3468 times)
jdjuggler
  • Last login:May 08, 2022, 10:54:37 pm
  • Hurray! I don't have pockets for quarters anyway!
« on: May 15, 2003, 02:54:33 pm »
I don't mind spending money on my cab.  But, Happs wants $53 for their 3" clear trackball.
Is there another (cheaper) source for 3" clear trackballs?  FWIW, I have a Betson/Imperial TB.
Thanks.
mastercave
  • Last login:July 07, 2003, 10:48:57 am
  • single player cp only
Re:Where to buy a 3" clear trackball
« Reply #1 on: May 15, 2003, 02:57:43 pm »
compusa sells a clear trackball, not sure if its 3" though
edit: i'm seeing it for $23 on the happs site. trans. blue 3"
http://www.happcontrols.com/trackballs/950029xx.htm
« Last Edit: May 15, 2003, 03:09:07 pm by mastercave »
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: May 15, 2003, 03:18:18 pm »
Check out this thread:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=6582;start=msg46275#msg46275
Apparently the juggling balls at www.extremespin.com are perfect replacements for 3" Happ trackballs.
I don't see any perfectly clear ones, but there's a clear one with sparklies in it, and there are some translucent colored ones that are much much lighter than the happ ones so they are practically clear.  Also, I bet you could get clear if you contacted the company.
Best Kid iPad Apps
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #3 on: May 15, 2003, 06:00:18 pm »
"Acrylic Juggling Ball
Crystal clear acrylic balls in three different sizes! These are great for contact juggling or regular juggling! These are also extremely strong, yet relatively lightweight. Not sure what size to get? Click here for recommendations.
Sizes are by diameter, prices range from $13 to $22 "
Extreme Spin has the clear 3" for $22.
If you build a frankenpanel, chances are I don't care for you as a person.
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« Reply #4 on: May 16, 2003, 10:46:18 am »
Looking at his screen name you'd have thought they he would of known about juggling balls   ;)
jdjuggler
« Reply #5 on: May 16, 2003, 11:43:28 pm »
Actually, yes, I'm very aware of acrylic juggling balls.  I don't think they have the weight of the trackball, but I may have to give it a try.
Thanks.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: May 17, 2003, 09:01:07 am »
Thanks.
Yes, I believe they are lighter than the white trackball balls; but the colored balls at happs are also lighter than the whites, IIRC (or is it just the transparent balls?).  Never the less, contact juggling balls are on the hefty side, and probably are about the same weight as the transparents at happs.  It's the juggle juggling balls that are a lot lighter than the same size TB balls.
But IANACJ (I am no a contact juggler), so I'm not possitive on the exact weights;  my knowledge is from the REAL juggling side. ;)
Robin
Knowledge is Power
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #7 on: May 17, 2003, 09:28:17 am »
i am currently usingone and also TheDemo is.  As far as I can tell they are exactly the same wheith and diameter.  for half the price it is perfect.
