Author Topic: Romlister and Emumovies HQ previews  (Read 1340 times)
slsimon
  • Last login:February 16, 2012, 11:49:12 am
« on: January 02, 2008, 04:29:54 pm »
Hey all.  Just me again :D.  I figured out how to use Romlister to move clone roms as well as mature roms.  I plan on using the Mala screensaver with the emumovies HQ previews.  Is there a way to easily remove the avi video previews that are associated with those roms that have been moved/deleted from the roms directory?  You will see 4 txt files attached.  Two txt files are the code that I used to remove the mature and clone roms while the other two are for removing the avi's associated with the roms by name.  Now, the problem is, I don't think the emumovie names are the same as the roms names.  Correct me if I am mistaken here.  But the bat files to remove the avi files errored out, (could not find the file name specified).  I don't think it would be appropriate for the kids and guests to view those not so nice pictures, (mature).  Please see attached...
Lakersfan
  • Last login:January 18, 2026, 05:42:06 pm
Re: Romlister and Emumovies HQ previews
« Reply #1 on: January 02, 2008, 06:03:12 pm »
Yes, in RomLister when you set up your batch file settings, change ".zip" to ".avi"
So your batch file command should be something like this: "move %roms%.avi c:\mame\avis"  Then place this newly created batch file in the correct emumovies folder and run it. Make sure you have a avis folder created in your c:\mame folder.
I thought the emumovies names were the same, no?
« Last Edit: January 02, 2008, 06:05:08 pm by Lakersfan »
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #2 on: January 04, 2008, 11:19:24 pm »
For mame yes, for consoles, it depends, most are in the Good format.
My Websites
