Author Topic: Motherboard AGP upgrade question  (Read 1009 times)
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« on: December 26, 2007, 08:13:14 pm »
I'm wanting to upgrade the old 128mb vid card in a system I have but I'm a little (ok, alot) behind the times. The manual says that the AGP slot is a 4X. Can I run 8X in it? Does anyone have any good suggestions/recommendations on what card to purchase? I like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161205
but I don't think I got enough mobo to run it.
I'd like to keep it under $150 if I could. Other than that I really don't care what I get. I'll probably upgrade the PSU also.
-HarumaN
SpeedEng
  • Last login:May 26, 2015, 01:31:42 am
  • one day I will finish
Re: Motherboard AGP upgrade question
« Reply #1 on: December 26, 2007, 08:59:08 pm »
wow for mame thats overkill!!
unless your using that system as your htpc :)
even you current card with 128mb is more than enough (unless it's one of those TC cards)
SpeedEng
« Reply #2 on: December 26, 2007, 09:01:48 pm »
opps and if the mb agp is 4x the 8x agp card will only run at 4x :(
honestly for 129 just for the agp I would save up and buy a c2d mobo (using pci-e) and cpu
IG-88
« Reply #3 on: December 26, 2007, 10:10:32 pm »
Well actually it's for various PC games I plan on running on the machine in the future. I wasn't necessarily getting it for mame. You should see some of the other machines I have. I got a 166 mhz w/16mb ram and a 2mb ISA vid card in a half completed bartop that runs the classics perfectly.  ;)  I actually like testing out various Inde' games and retro remakes that I find scattered about. Some of them now are asking for more horsepower than this old soon-to-be-upgraded-to-arcade-cabinet PC can handle. Hence the Vid Card question.
So I gather from what you said an 8X card will only run at 4X on this mobo, hmmm....The card in it now is a 128mb. Wonder if I found a 512mb 4X card. Would that be worth the investment you think??
-HarumaN
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #4 on: December 27, 2007, 01:33:01 pm »
I'm guessing you're running a machine 1.8ghz or less, correct?  The 512 VC you ask about, IMO, won't help you.  I'm in a similar position as you with a secondary machine and the machine itself is the weak link, not the video card.   You might want to save for a newer machine...
IG-88
« Reply #5 on: December 27, 2007, 05:03:28 pm »
Yup, a 1.6 to be exact. I've thought about maxing out the Ram, CPU and the vid card, but you are probably right, maybe I should save up for a newer build.  :-\
-HarumaN
SpeedEng
« Reply #6 on: December 28, 2007, 10:12:03 am »
yea no real point in upgrading you v-card
it's your cpu that is the bottleneck for gaming and mame
depending on your mb you can upgrade the proc (for quite cheap) and that will make a world of difference
