Author Topic: Regular Mala Error Help!  (Read 3972 times)
Trebeck
  • "The Arcade" - Build #4
« on: December 22, 2007, 02:49:43 pm »
Hi all,
I am getting shut down by Mala quite often and I would love to find out why.  Can anyone help with this error?
2007/12/22  11:45:15.88   Error: Object Class: TTimer, Object Function: DisplayVideo, Exception Class: EListError, Exception Message: Der Index der Liste überschreitet das Maximum (2346)
Beck
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Regular Mala Error Help!
« Reply #1 on: December 22, 2007, 03:24:09 pm »
Does it happen when you change emulators or randomly?  Are you using custom game lists?  Does it always happen while you are in one particular game list?   You may have to do a clean install of Mala (not an over-the-top install) before its all over.
Trebeck
« Reply #2 on: December 22, 2007, 03:41:26 pm »
It happens when I switch layouts more often than not.
I do have a few custom lists but I'll nuke them to see if it makes a difference.
It never happens in the middle of a game. Only when I switch layouts or exit a game.
loadman
  • Moderator
    • MaLa
« Reply #3 on: December 22, 2007, 04:55:52 pm »
Best Guess is that is upset about a particular graphic, either in the layour or in a snapsot/vid in a game list. Try and identify at what point(s) it happens to see if there is a pattern. If so it may be a case of replacing a couple of pics/vids.
Trebeck
« Reply #4 on: March 29, 2008, 10:17:30 pm »
Well, I've completely redone all of my Mala files and it seems to be stable now.  Now weird crashed for three days at least.
Goblins in the machine.....
loadman
  • Moderator
    • MaLa
« Reply #5 on: March 30, 2008, 05:02:55 am »
