Author Topic: Power down  (Read 1687 times)
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
Power down
« on: November 28, 2007, 07:45:54 am »
Right now I'm using Win2K w/ Mala as a front end.
Am looking for a way to shut the whole thing down
easily but "correctly" (ie. not the power switch)
w/o having to go into the Start Menu and select
Turn off computer then Shut down like I'm doing now.
Any suggestions?
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: Power down
« Reply #1 on: November 28, 2007, 08:04:23 am »
Are you using ATX hardware? If so, what's wrong with the power switch? There is nothing 'incorrect' with that!  It will shut your system down in the same way as the start menu then selecting shutdown.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
Re: Power down
« Reply #2 on: November 28, 2007, 09:16:39 am »
yep...
when i want to power down...all i do is hit the power switch...xp closes everything and then shuts down...
nice... :cheers:
vidmouse
    • Vidmouse's Arcade
Re: Power down
« Reply #3 on: November 29, 2007, 11:45:36 am »
Yer right.  Guess I needed to try it.
For some reason I thought doing this would
cause my PC to go into Scandisk mode on startup.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
Re: Power down
« Reply #4 on: November 29, 2007, 12:58:36 pm »
I use MaLa on W2K too. When I hit ESC MaLa prompts with "Shutdown?". I think you can configure how that works from the GUI and then MaLa Exit tabs. I use a SmartStrip so the rest of the cabinet follows the PC down.
-pmc
