Author Topic: Do vertical games work fine on a TV?  (Read 1651 times)
Wiibound
  • Last login:November 09, 2008, 04:48:18 am
« on: November 17, 2007, 02:00:03 am »
such as Galaga or Ms. Pac-Man on a 27" TV?
Justin Z
  • Last login:December 18, 2025, 09:47:41 am
Re: Do vertical games work fine on a TV?
« Reply #1 on: November 17, 2007, 10:30:49 am »
Depends on how much of a "purist" you are, I suppose.
Basically you end up with the equivalent of a 19" monitor rotated vertically when you put a vertical game on a horizontally-oriented 27" TV.
For my purposes, it works superbly, but others will probably disagree.
Wiibound
« Reply #2 on: November 17, 2007, 11:51:02 pm »
Yeah that was my thinking with the 27" TV so since the older games used vertical 19" monitors (isn't it funny how much taller they look when turned sideways?) it'd be the same size.. but other than that, no refresh/sync issues?
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 09:18:11 pm
« Reply #3 on: November 18, 2007, 12:44:49 am »
If your TV can handle PAL modes, then you won't have a problem.  PAL is better at modes with lots of vertical lines (and a refresh rate closer to 50khz), like 352x288 for galaga & pacman.  But this doesn't matter if you mount the screen vertically.
I have several cabinet, including two dedicated verticals with TVs as monitors (both Scart RGB) .
I use a 26" Loewe TV as a dedicated vertical monitor, and it rocks for vertical shooters like Twin Cobra and Flying Shark!
I also use a 21" TEAC TV vertically mounted into a classic-style low-boy retro cabinet (wood-grain finish).  For some reason, classic era games like galaga, DK and 1942 feel best on the small screen!  Vertical orientation on monitor is really good, lots of fun.  Much better "feel" than playing galaga on a horizontal 27" screen.
Wiibound
« Reply #4 on: November 19, 2007, 02:49:46 am »
isn't PAL the european standard?
Zebidee
  • Trade Count: (+9)
« Reply #5 on: November 19, 2007, 05:47:59 am »
Pal is a standard used in Europe, Australia and other places.  Most TVs I've encountered support both PAL & NTSC to some extent or another.
