Author Topic: Which Dreamcast VGA adapter to get?  (Read 1753 times)
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« on: September 23, 2007, 11:04:52 pm »
Anyone have any suggestions on where I should get a Dreamcast VGA adapter?  I see a few on ebay but I'm not sure of the brand.  Does it make a difference or do they all perform the same?
northerngames
  • Trade Count: (+18)
Re: Which Dreamcast VGA adapter to get?
« Reply #1 on: September 24, 2007, 10:53:10 am »
the cable type you snip back pin 6 on the end that goes intot he system and on the box type you snip wire 6 on the inside of the box.
the clear case hais vga box on ebay work fine but some moniotrs require a amp to display the DC right and mine was one of them.
if your going to use it for vga only then nothing needs to be done to them but for a 15K display the pin/wire #6 needs to be clipped.
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #2 on: September 24, 2007, 03:00:02 pm »
A couple of years ago I bought a Naki VGA-box because it was very cheap. I use it straight into a VGA display and it works perfectly. I don't think there's a huge difference between VGA boxes given that the DC outputs a VGA signal natively. If you're going straight into a monitor and don't need to mod it, I'd go with the cheapest one that has all the outputs you need.
-pmc
northerngames
« Reply #3 on: September 24, 2007, 04:47:35 pm »
yeah there all the same really.
crashwg
« Reply #4 on: September 25, 2007, 01:28:48 pm »
I've got an official Sega brand VGA adapter and couldn't be happier!  I did have to spend more to get it that you would on a 3rd party one but generally speaking, you can't get better products than first party peripherals.
P.S.
I believe I spent like $60-70 on ebay for it in case you were wondering.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
