Author Topic: Monitor color issue  (Read 1795 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
Monitor color issue
« on: July 07, 2007, 05:35:56 pm »
I'm pretty sure this is something to do with the monitor because it happens with two boards.  So I have a killer instinct cab with a golden tee 99 board in it. And at first the monitor worked fine now the colors are off purple is like a yellow, and none of the colors are correct, could this be  because it is in a building and it gets hot in there?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
grantspain
Re: Monitor color issue
« Reply #1 on: July 07, 2007, 05:44:39 pm »
its possible the degauss is not functioning or a colour drive transistor is shot,i don't believe heat is a problem
Hawk Daddy
« Reply #2 on: July 08, 2007, 01:22:32 am »
How do I fix Either of those?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Jeff AMN
    • Gamer Theory
« Reply #3 on: July 08, 2007, 01:57:25 am »
Have you moved the cab, or even just rotated it at all? My Donkey Kong had some pink issues until I changed it from facing east to facing south and that cleaned it up.
grantspain
« Reply #4 on: July 08, 2007, 06:12:26 pm »
if its a degauss isssue then moving a magnet around the screen would help to see if the colours return,if thats the case then you would need to replace the ptc component
if it makes no difference or makes it worse then you need to look towards the drive transistors
to be honest a pic of the problem would help a hell of a lot more
ESDAVE
  • Last login:February 21, 2008, 08:59:55 am
« Reply #5 on: July 20, 2007, 10:24:18 pm »
hi hawk did you get your color right on your monitor?.if not let me know i can give you easy to follow information. make sure coils round tube neck are not loose. kind regards dave UK.
