Author Topic: ROBOTRON cabaret / mini  (Read 10988 times)
RayB
  • I'm not wearing pants! HA!
  • Last login:July 10, 2025, 01:33:58 am
  • There's my post
    • RayB.com
« on: May 26, 2007, 08:36:49 pm »
Picked up a converted Robotron mini. It won't be easy restoring this thing... Only original things left is the bezel. Everything else is either missing or converted and painted over.
I will need:
- marquee
- control panel overlay
- remove paint from sides
- stencils (if sides don't turn out)
- game board
- power supply or a switcher convertor
- power circuit board
« Last Edit: June 08, 2008, 02:40:27 pm by RayB »
NO MORE!!
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: New Project: ROBOTRON Mini
« Reply #1 on: May 27, 2007, 01:52:48 am »
Here is a little inspiration to get you started:
http://forum.arcadecontrols.com/index.php?topic=63639.0
Have fun... :cheers:... I sure did...
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
RayB
  • There's my post
    • RayB.com
« Reply #2 on: May 27, 2007, 11:37:49 am »
Thanks for the link. This is my first Williams cab. What is the purpose of the metal joystick plates?
NO MORE!!
SirPeale
  • Green Mountain Man
« Reply #3 on: May 27, 2007, 03:41:26 pm »
Mounting the joysticks, I believe.
RayB
  • There's my post
    • RayB.com
« Reply #4 on: May 27, 2007, 06:57:23 pm »
ok, ZING. Got me...
Does it have bolts welded to the plates?
NO MORE!!
ArtMAME
    • Art's Arcade Lab
« Reply #5 on: May 28, 2007, 08:17:13 am »
If I remember correctly, they are just countersink wood screws.
The plastic joystick dust washer actually goes under the mounting plates and moves freely in there.  You screw the plates back on and the new CP overlay will go over it.
RayB
  • There's my post
    • RayB.com
« Reply #6 on: May 28, 2007, 10:47:16 am »
I guess what I'm wondering is, did Williams mount their joysticks so that the bolts went through the top of the CP, like most companies did, or was this plate so that there were no carriage bolt heads on the CP?
Like I said, Im not familiar with Williams cabs, so PEALE, what may seem obvious is not.
NO MORE!!
SirPeale
« Reply #7 on: May 28, 2007, 11:13:54 am »
Dude, WTF?  I gave you an answer, and you're getting pissy?
RayB
  • There's my post
    • RayB.com
« Reply #8 on: May 28, 2007, 02:09:57 pm »
It sounded like sarcasm. You know, like "What's a monitor mounting bracket for?  A: For mounting the monitor."
What happened is the only reference I've seen is Prok's reproduction control panel, and in his small photo it looked like these metal plates are merely attached to the bottom of the wood. So I wondered what they are for, considering one could just mount to the wood without the plates.  But Artmame explained it fairly well. It's like trackball mounting plates, where it's flush with the TOP. And so now I realize Prok's photo was a top view!
« Last Edit: May 28, 2007, 02:12:20 pm by RayB »
NO MORE!!
RayB
  • There's my post
    • RayB.com
« Reply #9 on: May 28, 2007, 02:13:39 pm »
Photos:
I have alot of work ahead.. It's kind of a turd right now.
NO MORE!!
SirPeale
« Reply #10 on: May 28, 2007, 02:15:48 pm »
Naw, man; that's hella sweet.  I'm envious.  At least you have a bezel.
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:Yesterday at 12:11:49 pm
  • Worthless button pusher!
« Reply #11 on: May 29, 2007, 09:27:18 am »
Looks good, RayB!
Once again you take home a project that makes me regret not being at the auction.
Working: Not Enough
Projects: Too Many
Progress: None
ArtMAME
    • Art's Arcade Lab
« Reply #12 on: May 29, 2007, 10:30:29 am »
The mounting plates are just there to hold the dust washer inside.  The actual joystick mounting is done with bolts and T-nuts embedded into the wood.  Check out the pics:
http://forum.arcadecontrols.com/index.php?topic=63639.msg634847#msg634847
The 4 outer holes (small) hold the plate onto the wood with wood screws.  The 4 inner holes (larger) hold the T-nuts and the joystick bolts enter from the underside of the CP to meet the T-nuts on top.
SirPeale
« Reply #13 on: May 29, 2007, 11:24:05 am »
Ah!  I did the same thing with the Super High Impact conversion I got.  Except I used plexi instead of a metal plate.
DARRYLICSHON
  • Last login:February 20, 2008, 04:11:03 pm
  • I wish i didn't love vides games so much
    • DARRYLICSHON
« Reply #14 on: May 31, 2007, 07:24:29 pm »
good luck, i have been looking for a robotron cab to restore also.Darrylicshon
Missile Command RULES !!!!!!
