Author Topic: Grab opinions on used tool deals here  (Read 12342 times)
Chris G
Re: Grab opinions on used tool deals here
« Reply #40 on: July 06, 2007, 11:43:02 am »
it would have been a perfect setup to get mugged raped and worse.
Don't worry... if you're ever away from the board for more than a few hours, we'll know something's up and alert the authorities.  ;D
« Reply #41 on: July 18, 2007, 11:48:14 am »
http://boston.craigslist.org/sob/tls/376503230.html
Cabinet saw... 14" cabinet saw would be really big, yes?
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #42 on: July 19, 2007, 11:27:53 am »
Yes, 14" saws are very huge... and difficult to find blades for. The 5HP motor would require 220V power... or maybe 3-phase? I forget where the cut-over point is. 120V will get you about 1.5HP, I thought 220V was only good to about 3HP but maybe I'm mistaken.
« Reply #43 on: July 20, 2007, 09:49:59 am »
3HP continuous, I'd guess, but I see a lot of 110v motors rated that high (probably at peak) or higher.
ScottS
« Reply #44 on: July 20, 2007, 10:26:04 am »
There are many different types of motors and horsepower numbers are computed/measured/exaggerated somewhat differently for each type. A 3HP router than runs on 120V is completely different than a 3HP tablesaw motor, which requires 220V...
If you compare specs for tablesaws, you'll see that you can't get much more than 1.5HP with 120V. Some will claim 1.75HP, but I tend to think they're exaggerating. To get more power, you have to go to up 220V. Once you max out 220V, you have to use 3-phase industrial power. Don't remember where the cross-over point is but somewhere in the 3-5HP range I'd think.
« Reply #45 on: July 20, 2007, 10:34:24 am »
Given the style of mobile carts and "set it up and then put it all away" workshop I have envisioned, 220v is definitely not practical.
ScottS
« Reply #46 on: July 21, 2007, 10:39:59 am »
Then you're probably limited to a 1.5HP contractor's or hybrid tablesaw. I used to think that 220V was impractical, too. Then I bought a welder that required 220V. So I made a 50-foot 220V extension cord that plugs into a welder at one end and and my inconveniently located dryer plug at the other end. The cord cost $60 or $100 to make, but now I can use 220V pretty much anywhere in the garage or driveway. When I'm done, I coil the extension cord up, roll the tools away, and plug the dryer back in...
« Reply #47 on: August 06, 2007, 02:48:09 pm »
Hrm... guy from Craigslist is still emailing me about a Craftsman 100 series tablesaw... it's a bit far, but if it is in good shape, $75 for it would be a steal.  Need more info on condition.
This is just a random net source but I think this may be the type of saw.
