August 31, 2025, 06:05:34 pm
Not exactly an Admin button, but another button, none-the-less.Can I connect the PC Power button to a normal Arcade Button (microswitch) to boot the PC up? (I want to locate it on the back of the cab, but easy to locate and turn on).I was told PC Power button is a momentary switch, is that the same thing as the common cab button?
The more buttons you add to your cp, the more confused your guest will be. Luckily I figured this out on my "test build" cp.
