Author Topic: Galaxy Dimensions  (Read 1869 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Galaxy Dimensions
« on: April 13, 2007, 08:47:09 pm »
I am looking for dimensions for a Galaxy dartboard, doesn't have to be exact but close.
Bottom Piece
Height, Width and Depth
Top Piece
Height, Width, and Depth
I b**ch. People listen!!
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: Galaxy Dimensions
« Reply #1 on: April 13, 2007, 10:37:58 pm »
This might help.  I assumed you meant the original Galaxy, and not the Galaxy II.
Found this in the manual:  http://www.arachnidinc.com/support/docs/GalaxyManual.pdf
It isn't exact, but it does show the base size.  Perhaps you can figure out the rest.  Weight is about 230lbs.
« Last Edit: April 13, 2007, 10:39:52 pm by modessitt »
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
squirrellydw
« Reply #2 on: April 14, 2007, 09:27:34 am »
yeah I have that, it doesn't give me what I need though
modessitt
  • Technician
« Reply #3 on: April 14, 2007, 08:41:41 pm »
The last one I delivered was approximately split in half.  When taken apart, both pieces were the same height and width.  The top Piece sticks out farther than the bottom piece for the lights.  You can take what you know about the base width and height and use it as a reference when figuring out the rest, can't you?  For example, if the top depth is about 1/2 the bottom, thus divide the bottom depth by 2.  You should get pretty close.  Or, I know a bar in Texas where you could show up with a tape measure....
squirrellydw
« Reply #4 on: April 15, 2007, 08:12:02 pm »
I am going to bar tomorrow that has one, will post the dimensions for anyone that wants them
Ed_McCarron
« Reply #5 on: April 15, 2007, 09:59:16 pm »
80,000 to 100,000 light-years in diameter.
Sorry.  Couldn't resist.
squirrellydw
« Reply #6 on: April 16, 2007, 08:31:49 pm »
TOP
41" High (36" high with out the lights)
12" Deep
25 1/2" Wide
Bottom
43" High
16" Deep
25 1/2" Wide
41" from bottom to front of slope
43" from bottom to back of slope
Slope is 4 1/2" deep
I am going to build mine with out the lights do to the height.  Total height will be about 79 to 80 inches.
