Author Topic: is there a way to cut a "hole" in an Illustrator layer?  (Read 1423 times)
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« on: April 13, 2007, 11:33:01 am »
like..if you make an "O" do you have to make a top circle with another layer circle inside it that has the background color?  it seems like you should be able to cut a hole or make a section of something transparent without making the entire layer transparent....ya know?
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
4Aaron GE
  • Last login:July 22, 2013, 10:27:07 pm
Re: is there a way to cut a "hole" in an Illustrator layer?
« Reply #1 on: April 13, 2007, 01:05:19 pm »
Look for a shaping tools menu.  This is a basic function in CorelDraw (which I use), so it has GOT to be in Illustrator somewhere.  You know how you can merge/weld two layers together?  There should be a function near that to use one layer to trim the other.
allroy1975
  • I'm a dork!
    • Matt's Mame
