Author Topic: hiscore diff (with no nag/white box removal)  (Read 656234 times)
abelenki
  • Last login:December 21, 2022, 06:58:00 pm
    • MAME Stuff
Re: hiscore diff (with no nag/white box removal)
« Reply #760 on: June 11, 2013, 06:17:56 am »
hi_148u5.diff seems to work fine with 0.149 source tree, but with some warnings.
it doesn't compile at last...
« Last Edit: June 11, 2013, 06:38:04 am by abelenki »
MAME Stuff | MAME favorites | Bubble Bobble Series chart / wiki | PC configuration
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #761 on: June 11, 2013, 06:36:17 am »
Without warnings (here).
« Last Edit: June 11, 2013, 07:08:07 am by Ansa89 »
Earth could be the hell of another world
abelenki
    • MAME Stuff
« Reply #762 on: June 11, 2013, 06:39:43 am »
Without warnings.
thank you!! i will try to compile 0.149 now, because it doesn't compile with 0.148u5 diff.
abelenki
    • MAME Stuff
« Reply #763 on: June 11, 2013, 06:50:32 am »
hmm, it still doesn't compile:
Compiling src/osd/windows/window.c...
src/osd/windows/video.c: In member function 'virtual void windows_osd_interface::update_hi(bool)':
src/osd/windows/video.c:246:42: error: too few arguments to function 'void winwindow_process_events(running_machine&, int
, bool)'
src/osd/windows/window.h:167:6: note: declared here
make.EXE: *** [obj/windows64/osd/windows/video.o] Error 1
make.EXE: *** Waiting for unfinished jobs....
Ansa89
« Reply #764 on: June 11, 2013, 07:04:47 am »
The interface of that function has changed (they added a parameter), so I tried to add a "FALSE".
NOTE: at the moment I can't build windows binaries, so I'm unable to test the new patch.
abelenki
    • MAME Stuff
« Reply #765 on: June 11, 2013, 07:24:36 am »
compiles fine now, thanks a lot!!
Ansa89
« Reply #766 on: June 11, 2013, 07:55:31 am »
Please double check if the compiled binary has the correct behavior at execution time (for example: hide/un-hide nag screen works correctly).
abelenki
    • MAME Stuff
« Reply #767 on: June 11, 2013, 10:14:06 am »
yes, everything works perfectly (no nag screen, no loading status).
thank you once again.
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
« Reply #768 on: June 11, 2013, 10:43:11 am »
Thanks Ansa89 for updating it!
Thanks abelenki for hosting it!
Updated the front page.
abelenki
    • MAME Stuff
« Reply #769 on: June 11, 2013, 10:44:42 am »
wolfsoft
  • Last login:September 01, 2024, 05:27:47 pm
« Reply #770 on: June 11, 2013, 11:12:58 am »
I copied the highscore.dat into the hi folder and its working great now :-)
thanks
I tried groovymame 0148u5 and compiled the diffs to u5 and the your u5 diff
i put in the current highcore.dat in mame root... and highscorepath is created
but it didn't generate hiscore files in the hi path... and eg. pacman is not saving the highscore.
nagscreen and loading patch is working...
Do I miss something?
mame.ini
hiscore_directory         ..\common\hi
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
« Last Edit: June 11, 2013, 04:01:08 pm by wolfsoft »
http://www.blog.wolfsoft.de for arcade tutorials
http://www.wolfsoft.de for our website
wolfsoft
« Reply #771 on: June 17, 2013, 05:50:04 pm »
I am searching a patch for mame 0148u4 and didn't find a download here.
As far as I can see the hi_148u2 seems to work but I can't find a download
thanks
cheers from germany
wolfsoft
« Reply #772 on: June 19, 2013, 04:25:31 pm »
please help me, I want to make a hbmame work with highscore and nonag...
cheers
abelenki
    • MAME Stuff
« Reply #773 on: June 20, 2013, 04:23:39 am »
cheers
it will be difficult, because HBMAME builds are not tied to MAME full and u-releases. instead, HBMAME is built off SVN (which is updated almost daily).
when next HBMAME is released, you can try to apply latest hi_***.diff to its source tree. but it's not garanteed, it will work.
wolfsoft
« Reply #774 on: June 21, 2013, 03:37:10 pm »
it is based on 0148u4.
As the 148u2 diff seems to work with mame 0148u4... it should work on the hbmame version...
Please upload the 0148u2 diff and I will have a try
thanks in advance
neil324
  • Last login:October 07, 2013, 03:53:50 am
« Reply #775 on: June 29, 2013, 10:55:21 am »
I'm trying to patch Mame 1.06 to remove the nag screens. To use on a slow PC. There doesn't seem to be a .diff for this release and the others don't work.
Is there a patch or way to edit the .diff for 1.06
abelenki
    • MAME Stuff
« Reply #776 on: June 29, 2013, 11:00:49 am »
there were never such a version of MAME.
the earliest MAME version for which hiscore diff is available is 0.108.
« Last Edit: June 29, 2013, 11:02:31 am by abelenki »
neil324
« Reply #777 on: June 29, 2013, 12:42:02 pm »
MAME started at 0.1
I'm trying to remove the nag screen as hi scores still worked in MAME 1.06. The hiscore diff has the patches to remove the nag screens before you compile the MAME of your choice.
abelenki
    • MAME Stuff
« Reply #778 on: June 29, 2013, 12:46:31 pm »
MAME started at 0.1
sure.
lol. there was no MAME 1.06. :D current MAME version is 0.149.
neil324
« Reply #779 on: June 29, 2013, 12:50:00 pm »
0.106
You know what I meant though ::)
The 0.1 was correct though, going by the MAME website :applaud:
abelenki
    • MAME Stuff
« Reply #780 on: June 29, 2013, 12:57:48 pm »
0.106
as i already said:
the earliest MAME version for which hiscore diff is available is 0.108, so no luck with 0.106.
neil324
« Reply #781 on: June 29, 2013, 01:07:19 pm »
0.106
Is the hiscore diff the only way to patch MAME to remove the nag screens.
bidinou
  • Newbie
  • Last login:February 07, 2014, 09:35:43 am
« Reply #782 on: July 08, 2013, 04:50:01 am »
Hi ! Applied the patch with no pb under Linux (Mint 15 64 bits, MAME 0.149).
I have a question though : the disable_loading_patch option doesn't work. Well, it seems to be taken into account to some extent because it displays two white rectangles at the end of the loading but that's it.
Thanks !
abelenki
    • MAME Stuff
« Reply #783 on: July 23, 2013, 03:54:57 am »
hi_149.diff works fine with 0.149u1 source tree.
CalixPapi
  • Last login:January 19, 2016, 11:30:47 am
  • I want to build an arcade, not 1 machine, plenty
« Reply #784 on: August 08, 2013, 03:35:49 am »
Can  I please get some help I keep getting this error.
I am trying to do 0.149 have also tried with 0.146
I enter patchmame hi_146 or patchmame hi_149
Have even tried patchmame 0149u1 then patchmame hi_149 then makemame
CalixPapi
« Reply #785 on: August 08, 2013, 09:37:18 pm »
I even get the same error when trying to compile the regular mame. What am I doing wrong?
CalixPapi
« Reply #786 on: August 09, 2013, 01:57:58 am »
would it be possible to compile this on my win7 laptop and then put it onto my winxp laptop? I am using the xinxp laptop for my build but want to get rid of the nag screens.
Ansa89
« Reply #787 on: September 18, 2013, 05:16:43 am »
Thanks for the upgrade :) .
EDIT: the new patch is wrong: instead of modifying "src/emu/emuopts.c", it creates a new file "src/emu/emuopts.c.rej" (which will be probably ignored by mame at compile time).
« Last Edit: September 19, 2013, 05:40:01 am by Ansa89 »
Ansa89
« Reply #788 on: September 19, 2013, 05:44:00 am »
Here is my patch (IMHO this should be correct).
MKChamp
  • Stil around.
« Reply #789 on: September 19, 2013, 10:57:03 am »
If actually modified emuopts.c as well. I removed the .rej. Thanks for pointing it out!
Ansa89
« Reply #790 on: September 20, 2013, 05:25:02 am »
Sorry for still complain, but seems you forgot the "OPTION_DISABLE_*" options:
--- orig/hi_150.txt 2013-09-19 16:52:24.000000000 +0200
+++ new/hi_150.txt 2013-09-19 11:22:56.376538336 +0200
@@ -31,6 +31,18 @@
  // state/playback options
  { NULL,                                              NULL,        OPTION_HEADER,     "CORE STATE/PLAYBACK OPTIONS" },
+@@ -204,6 +208,11 @@
+ { OPTION_HTTP,                                       "0",         OPTION_BOOLEAN,    "enable local http server" },
+ { OPTION_HTTP_PORT,                                  "8080",      OPTION_INTEGER,    "http server listener port" },
+ { OPTION_HTTP_PATH,                                  "web",       OPTION_STRING,     "path to web files" },
++ // MKChamp Hiscore Diff options
++  { NULL,                        NULL,        OPTION_HEADER,     "CORE MKChamp OPTIONS" },
++  { OPTION_DISABLE_HISCORE_PATCH, "0",         OPTION_BOOLEAN,    "disable hiscore saving" },
++  { OPTION_DISABLE_NAGSCREEN_PATCH,  "0",         OPTION_BOOLEAN,    "disable suppression of nagscreens" },
++  { OPTION_DISABLE_LOADING_PATCH,    "0",         OPTION_BOOLEAN,    "disable suppression of loading screens /white box" },
+ { NULL }
 diff -Nru old/emu/emuopts.h src/emu/emuopts.h
 --- old/emu/emuopts.h 2013-09-17 01:47:03.000000000 -0500
 +++ src/emu/emuopts.h 2013-09-17 10:32:41.000000000 -0500
Is that a wanted change or simply a mistake?
Funkoid
  • Last login:July 31, 2023, 06:14:54 pm
  • Dreaming of more space...
« Reply #791 on: September 22, 2013, 05:49:43 am »
This is great work wish I'd found it years ago. It probably falls out the scope of this mod but I'd love to be able to have mame save the .hi file or an alternate copy of it once every hour or so, allowing me to read the latest hiscore tables whilst the rom is still running.
Doable?
MKChamp
  • Stil around.
« Reply #792 on: September 23, 2013, 04:01:33 pm »
Thanks again Ansa89...that was a mistake...I'm just getting sloppy...
WakiMiko
« Reply #793 on: September 26, 2013, 09:12:51 am »
Any reason why hiscores are lost when soft-resetting (default MAME key is F3)? They are kept over hard-resets (Shift+F3).
kjmann
  • Last login:November 23, 2013, 10:06:31 pm
« Reply #794 on: October 15, 2013, 10:07:12 am »
Hi There. I'm New Here, so bare with me.
After applying the .diff patch from here Using original mame .150, i keep getting this when I start mame....
« Last Edit: October 15, 2013, 10:08:59 am by kjmann »
BlackGreen
  • Last login:June 16, 2015, 08:01:26 pm
« Reply #795 on: November 04, 2013, 01:39:38 pm »
Thank you to MKChamp and Leezer for putting in the work for the hiscore system.
I was able to merg the changes with 0.148 without any problems.  Just required a full rebuild.
Thanks for your hard work!
abelenki
    • MAME Stuff
« Reply #796 on: November 05, 2013, 05:13:15 am »
hi_150.diff works fine with 0.151 source tree, but with many warnings.
compiled fine.
« Last Edit: November 05, 2013, 05:30:57 am by abelenki »
Ansa89
« Reply #797 on: November 05, 2013, 05:51:12 am »
Without warnings.
abelenki
    • MAME Stuff
« Reply #798 on: November 05, 2013, 06:05:21 am »
MKChamp
  • Stil around.
« Reply #799 on: November 05, 2013, 11:36:45 am »
Without warnings.
Gracias! I added it to the main page.
