Aight, hopefully a last question. The A button on my controller came unsoldered and took the contact with it, so I went ahead and hacked a second controller for the set-up. Because it's a Madcatz, I made sure to check that it worked before I opened it up (it did). After hacking it, I found that neither A nor X work at all, and the power/guide button is on the fritz, even when the button is not plugged in at all. I checked with a multi-meter, and the signal is coming through fine on the A and X buttons and they are both grounded. Additionally, all are set to NO. Anyone have any clue what's going on? It was suggested by someone else that there was possibly a short, and if anyone thinks they could help actually spot it, I could post a picture of the pad up. Thanks.
