Author Topic: SF2 cab update  (Read 2789 times)
govee
  • Last login:February 19, 2012, 09:26:30 pm
SF2 cab update
« on: February 17, 2007, 09:07:55 am »
I got the cab home last night and realized It says SF2 Championship Edition Turbo Hyper Fighting on the Marquee but the Side art says only SF2 Champ Ed and upon further review the board says only SF2. Is there a difference? Was it just a marketing ploy? Also when I turned on the cab the monitor came on for a couple seconds showed a red screen then went blank. The Marquee lights up but there is no sound. I checked and there is 120v coming out of the transformer but the ps has no 12v or 5v coming out. Here is some info from the cab. There is a placard on the back that says it is from ROMSTAR by DYNAMO, model number 02800500. The Monitor says Phillips A48ABK054
Here is a link with some pics.
http://akmd1.tripod.com/SF2.htm
« Last Edit: February 24, 2007, 05:43:47 pm by govee »
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: SF2 cab now at home. Need some help.
« Reply #1 on: February 17, 2007, 10:40:32 am »
The marquee and sideart would be correct. SFII Champion Edition was initially sold only as a dedicated cabinet (similar Dynamo cab, grey speckly artwork). Later it was sold as a kit to convert other cabs. Judging from the Romstar sticker (and the cab itself), yours would be a conversion. After CE was out for a short time, they released Turbo as an upgrade to CE boards. This is why they would have still had Champion Edition sideart.
I'm not sure if there's an easy way to identify which board you have.
govee
« Reply #2 on: February 17, 2007, 11:15:51 am »
I found a sticker in the bottom of the cab that says this is a WG19K7602. Definetly no power out of the PS. THe power supply is a Peter Chou.
govee
« Reply #3 on: February 17, 2007, 03:55:38 pm »
replaced blown fuse in PS and it blew the fuse for the transformer. Replaced the transformer fuse and left out the ps fuse and it is back to where it was. hmmm
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #4 on: February 17, 2007, 06:08:10 pm »
I will gladly default to someone who has much more experiance than I, but it sounds like you only have juice going to the monitor, but not to the board.
Mattiekrome
  • Last login:August 25, 2022, 12:34:49 pm
  • Laser Rocket Arm
« Reply #5 on: February 17, 2007, 07:26:30 pm »
Wow, lucky dog!  I've been trying to find some plans for a SFII cab, or even better yet, an original to gut for my first attempt at a MAME cab, and you happened to find one locally for $40...
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #6 on: February 17, 2007, 07:51:59 pm »
If you have a capacitance meter, check the caps on the PSU's main board and make sure you don't have any dead ones. Following that, if you have an IC Identifier, check that it reports the main power transistors properly.
Check all of the solder connections on the board and re-flow the solder on all of the pins. More often than not this will fix a lot of problems without doing anything else. Most of the monitor and PSU faults I fix fall into this catagory. I quite often do this before I even think about doing anything else.
If all of the above checks out, then you have a short circuit somewhere.... It's certainly a PSU Fault.
A at worst case a new PSU is very cheap.... about $40 USD at most. £25 GBP. Which makes it pointless repairing it if there are a lot of parts in a faulty condition.
The sticker you found in the bottom of the cab is a Wells & Gardner Monitor Part Number for a 19" K series monitor. It's possible that your cab has had a monitor change at some point.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: February 17, 2007, 07:59:52 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
govee
« Reply #7 on: February 17, 2007, 09:24:41 pm »
I was thinking of just ordering a PS. I have no real test equipment other than a meter so checking all else is a no go. So are you sing it is not a WG?
Andy
Fozzy The Bear
« Reply #8 on: February 17, 2007, 09:54:22 pm »
Andy
If your monitor says "Phillips" on it then I'll guess that was on the tube.....
It probably means you have a W&G Monitor Chassis using a Phillips Tube. That's quite common. Hantarex use Phillips tubes as well.
Best Regards,
Crowquill
« Reply #9 on: February 18, 2007, 04:06:40 am »
I'd guess you probably do have the original WG monitor, but monitors are easy to swap out if they have problems, so you never know. If you want to know for sure, compare against diagrams in the manual for the K7000 series of monitors. Here's a quick link:
http://www.hardmvs.com/html/Downloads.htm
If it were me I'd definitely replace the power supply. They're fairly cheap and you won't have to keep worrying about it.
govee
« Reply #10 on: February 18, 2007, 07:46:38 am »
I checked the Main PC Board Layout against that of the one in the manual and they match. Also the numbers on the board match that of the one in there as well. Whew, now I definitely now I have a none working WG19K7602 in this case.
Fozzy The Bear
« Reply #11 on: February 18, 2007, 08:36:12 am »
Sorry???? How do you work that out???  I think you're getting a bit confused here. It's your power supply that's failed not nessesarily the monitor or the monitor board. There's probably nothing wrong with the monitor.
Until you get the power supply to the game board working properly you won't get anything on the monitor. Take this ONE step at a time. If you have no 5v or 12v coming out of the power supply then fix that first.
Best Regards,
« Last Edit: February 18, 2007, 08:41:28 am by Fozzy The Bear »
govee
« Reply #12 on: February 18, 2007, 10:52:05 am »
Sorry , that was misleading. I was really just trying to point out that I know which monitor is in this none working cab. I realize that it has 120V in from the transformer and that it also needs all the video inputs from the ROM PCB but it is receiving power from the dead PS. The next thing is to get a working PS.
« Last Edit: February 18, 2007, 12:11:57 pm by govee »
skim36
  • Last login:September 03, 2015, 03:37:21 pm
  • "Where's the nearest restroom?"
« Reply #13 on: February 23, 2007, 01:07:59 am »
When I bought my SFII Dynamo cab...the manual was on the very bottom inside the cab...I might be able to find it for ya if interested.  I don't need it.
--skim36
govee
« Reply #14 on: February 23, 2007, 10:01:02 am »
Thanks for the offer Skim. I will let you know should I run in to isues that the manual could help with. For know I am going to do some cleaning and wait for the PS.
govee
Re: SF2 cab update
« Reply #15 on: February 24, 2007, 05:46:15 pm »
 ;D I got the PS in today and the cab works like a champ; earlier this week I took out the Marquee cause it was looking bad. I noticed it had a plastic yellowing film on it. 30 minutes with a scraper and it now looks great. Now I need to clean it.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
Re: SF2 cab update
« Reply #16 on: February 25, 2007, 10:21:48 am »
That awesome congrats govee :cheers:
My old user name was marlborroman13, but I kicked the habit many years ago!
