Author Topic: Glowing light around Wii disc slot  (Read 3563 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: January 11, 2007, 03:31:32 am »
When does the disc slot light up?  The only time I see it lit is for a split second when the console is first turned on.  Is this console defective?  I would have thought it would be glowing blue the whole time it is turned on, or at least when a disc-based game is being played.
Best Kid iPad Apps
AlanS17
    • AlanS17
Re: Glowing light around Wii disc slot
« Reply #1 on: January 11, 2007, 08:05:31 am »
I think it only light up for those moments when it expects you to insert a disc so that it can help you guide a disc into the slot. I think your Wii is fine. I'll double check with my own tonight. No time this morning. Getting ready for work.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #2 on: January 11, 2007, 08:08:23 am »
It lights up when you have a new msg.
crashwg
« Reply #3 on: January 11, 2007, 10:31:43 am »
If you want it to do more, I'd suggest...
http://sickmods.net/index.php?site=shop&cat=PulseVU
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
somunny
  • Is it hot in here?
« Reply #4 on: January 11, 2007, 11:48:19 am »
Add your email address to your Wii contact list then send yourself an email.  Reply to your Wii address and the blue light will come on.  Don't read that email and the blue light won't turn off.
I did this but had second thoughts about the blue light running 24/7.
  • Last login:Yesterday at 10:07:01 pm
« Reply #5 on: January 12, 2007, 01:43:13 am »
Yeah the email trick is cool but I wish it only worked when the console was powered up.  I suppose you could turn off connect24, but then the weather channel and such wouldn't work.
Hopefully nintendo will give us more control over it in a future update as it seems to be controlled via software.
