Author Topic: NFL Blitz 99 Arcade blown fuse at power up  (Read 2942 times)
luke4_44875
  • Newbie
  • Last login:December 27, 2006, 01:14:03 pm
« on: December 20, 2006, 07:45:33 pm »
I recently acquired  a NFL Blitz 99 arcade that blows the 3 amp fuse on the small transformer where power comes in at as soon as you power it up. If you unplug the monitor everything works fine. I was told that it recently had a cap kit and everything worked fine afterwards.The guy that had it before said it worked perfectly and then it suddenly went out. I think it has a dead short, the fuse blows instantly and is burnt black. Any ideas on where to start?
tommy
Re: NFL Blitz 99 Arcade blown fuse at power up
« Reply #1 on: December 20, 2006, 09:17:15 pm »
Lower the power on the power supply?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: December 21, 2006, 01:41:54 am »
What make and model monitor is it?
Unplug the degauss coil and see if it still blows.
If it does, then there is more than like a problem in the power supply section of the monitor. (H.O.T., voltage regulator, rectifier diodes, etc)
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #3 on: December 21, 2006, 08:12:53 pm »
Im far from a monitor guru.... but it sounds like someone powered their monitor without the isolation transformer.  I did this last week... and after that, all it would do is blow the fuse at the transformer from there on out.
i'd say your deflection board is toast.
grantspain
« Reply #4 on: December 22, 2006, 12:03:57 pm »
its a bit of a strange one,all i can think of is someone has overated the fuse on the monitor chassis and because of a dead short(either degauss circuit or primary power circuit diode)its blowing the fuse on the mains input-check the fuse rating on the monitor first,they are usually about 2 amps
also worth checking whether someone has cut into the monitor power input to provide the marquee lamp with power
