Author Topic: Opinion on marquee please  (Read 5995 times)
virtual930
  • Last login:June 18, 2008, 06:48:02 pm
« on: September 23, 2006, 09:58:15 pm »
I am working on a marquee for a cab I am going to build and would like to hear some opinions/suggestions.
I think the background needs something, but I am not sure what.
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
Re: Opinion on marquee please
« Reply #1 on: October 02, 2006, 11:27:31 am »
Excellent colours and simple clean design.  I like it.  What does the CP look like? :applaud:
Galaga... Was there any other game?
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #2 on: October 02, 2006, 11:59:44 am »
The problem is that there's too much of it. If you can't make the logo bigger, try adding a shadow or a horizontal stripe.
Make your cabinet look its best with custom art from
Gamecreature!
_) (V) (-)
  • Last login:November 19, 2018, 11:56:39 am
  • There's supposed to be an earth shattering KaBoom!
« Reply #3 on: October 02, 2006, 01:37:23 pm »
The lettering lacks definition, maybe it's all the horizontal lines or something but it makes it kind of hard to actually 'read' the name easily.  I'd suggest like Gamecreature said, make the lettering bigger or maybe fade the colors on the background just a little so the lettering stands out  more. Cool design, gets you attention like a road construction sign.
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« Reply #4 on: October 02, 2006, 01:49:05 pm »
Definitely set the text apart from the rest somehow so that it's easily read. The background washes it out a bit. Clean otherwise
FunWithFire
  • Last login:July 07, 2009, 01:17:30 am
« Reply #5 on: October 02, 2006, 03:31:22 pm »
I just did this super fast so it looks like crap, but how about a gradient that runs down the middle to help pull the text from the background?
releasedtruth
  • Projected Nexus
« Reply #6 on: October 02, 2006, 06:20:14 pm »
That might work. You have the right idea. With the backlighting the yellow will pop pretty significantly so you want to make sure your text is set apart, if that's your goal anyway...
SNAAKE
  • Trade Count: (+29)
  • Last login:November 01, 2025, 12:55:17 pm
« Reply #7 on: October 03, 2006, 05:08:06 am »
try blue+black+red outlines for the text and white glow :cheers:
« Last Edit: October 03, 2006, 05:11:03 am by SNAAKE »
virtual930
« Reply #8 on: October 03, 2006, 10:12:35 pm »
Wow didn't expect so many response so quick.
I don't know if I am going to have any artwork on the cp, I am leaning toward a modular control panel so artwork will be difficult add.
I will try a few of the suggestions this weekend and post any results.
And for the backlighting I might try having a extra sheet printed that is black with the red area of the letting in white, hoping to get an effect that only the letters are lit.
Also here is one I was toying with for fun. I might use something similar, haven't decide.
Thanks for all your input so far
Oddfeld
  • Last login:October 26, 2024, 04:46:39 pm
  • I was Jeff Minter's llama!
« Reply #9 on: October 04, 2006, 07:55:37 am »
I don't think red on yellow offers enough contrast for the type to stand out. You really need to do something to lift the title off those yellow bars. Here's a quick and dirty option with a black grad behind the type.
gamecreature
    • Gamecreature
« Reply #10 on: October 04, 2006, 11:22:18 am »
Trust me, the title needs to be bigger. You don't want it to get lost.
Gamecreature!
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #11 on: October 04, 2006, 03:18:32 pm »
Bigger text, black gradient in the middle.
After you enlarge the text, experiment with the black gradient size and transparency (or whatever the term is)
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
