Author Topic: monitor help plz  (Read 2516 times)
bradster25
  • Last login:November 28, 2006, 02:09:53 am
monitor help plz
« on: August 14, 2006, 12:08:41 am »
 :timebomb:  new to arcade machines..i got my first machine and the monitor wasnt hooked up i had a buddy of mine that has a few machines come hook it up but we got some smoke comeing off the monitor not off any wires but what looks to br around a metal pice im not sure what would cause this it it has him stumped aswell by the location of were the smoke is comeing from any help would really be helpful..is is a 19 inch Hantarex 900e....i got pics if needed..thnx
bradster25
Re: monitor help plz
« Reply #1 on: August 14, 2006, 12:15:08 am »
forgot to add the tube get really bright be4 smokeing
grantspain
« Reply #2 on: August 14, 2006, 09:10:53 am »
blimey smoke everywhere,the 900 had a 4 wire plug mains input which should have 240ac for degauss and 120ac for monitor maybe your friend wired around the wrong way-take a picture of where the smoke came from otherwise we will be guessing for weeks
i suspect if its the voltage around the wrong way then your bridge rectifier circuit would have blown along with the mains smoothing cap and fuse
if its just a coincidence and the monitor was already faulty then look towards the horizontal output transistor or frame ic or flyback transformer
bradster25
« Reply #3 on: August 14, 2006, 08:05:55 pm »
ok this monitor only has 2wire not four well add the ground so we will say 3...this is a 900e..how do i post pics?
« Last Edit: August 14, 2006, 08:11:13 pm by bradster25 »
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 15, 2006, 02:20:55 am »
how do i post pics?
Use the " Additional Options " below your reply text box. (easiest)
As long as the size is 512kb or less.
bradster25
« Reply #5 on: August 15, 2006, 11:05:07 am »
pics of monitor
bradster25
« Reply #6 on: August 15, 2006, 11:11:06 am »
looks like right  under the metal
grantspain
« Reply #7 on: August 15, 2006, 11:56:41 am »
that is modified for the u.s market so disregard the 4 wire plug,yours just uses an isolated 110v ac input but still look for the bad solder joints
grantspain
« Reply #8 on: August 15, 2006, 04:47:17 pm »
wow thats one old monitor,the pictures you posted don't show anything i would be concerned at,with something that age you have to look for bad solder joints and at worst the flyback transformer-by the look of your chassis it seems it may have been stored somewhere damp
bradster25
« Reply #9 on: August 15, 2006, 04:51:45 pm »
so were do you think the best place to start is?
bradster25
« Reply #10 on: August 15, 2006, 04:57:39 pm »
ill post a few more pics
bradster25
« Reply #11 on: August 15, 2006, 05:00:35 pm »
pic....
grantspain
« Reply #12 on: August 15, 2006, 05:06:20 pm »
very difficult to see but the red lead from the flyback to the anode cap on the tube looks burnt,is this the case?if so you will need a new flyback transformer(if you have any damage on this lead it will arc across to any metal work blue sparks
bradster25
« Reply #13 on: August 19, 2006, 07:37:31 pm »
thanx for the help i just went ahead and got a new monitor...it was the yoke that was smokeing
grantspain
« Reply #14 on: August 20, 2006, 04:10:45 pm »
first time i have ever seen a yoke smoke ;Di reckon your anode lead was arcing to the yoke deflection plates making it look like the yoke
« Last Edit: August 20, 2006, 04:52:47 pm by grantspain »
