Author Topic: would the sega genesis sports pad have the same trackball as in the arcade?  (Read 1352 times)
TheRed
  • Last login:July 17, 2010, 12:40:19 pm
  • Always help people.
I need a sega trackball....is the one in the sports pad for the genesis the same as in the sega arcade cabs?
DaveMMR
Doubt it highly - especially considering the extreme size difference.
TheRed
cool, thanks! Just looking for a cheap alternative. Plus I can't even find a sega trackball around :(
DaveMMR
Are Sega trackballs any different than Happs?  Because the Happs ones are pretty good.   Check the B/S/T.
TheRed
I don't know about trackballs too much, but someone told me something in sega track balls is "negative" while happs are "positive".
he said:
all arcade sega trackballs games from the late 80's, 90's and 2000's are the same.
And all use the same optical sense boards for the X/Y and use negitave logic.
These require the special optical/spinner and a Naomi I/O board to function.
Sega trackballs use negative logic, Atari and Happ use postive logic I believe.
Again....I don't really know what that means, but he does and I trust him enough to look for the right one before using the little money I have. :)
« Last Edit: August 01, 2006, 06:47:58 pm by TheRed »
