Author Topic: PinMame cab, next phase (monitor suggestions ???)  (Read 2080 times)
DefJam
  • Last login:February 11, 2024, 02:03:20 pm
« on: July 03, 2006, 02:44:44 pm »
Hi All,
I have the itch to make some changes to my cab and was hoping you all could throw some suggestions my way.
You can see the cab at:
http://home.comcast.net/~ataritoday/
Ok, so I'm really itching to get a bigger monitor and move it closer to the player...   Currently a 19 inch computer monitor.  The new monitor needs to look good while playing PinMAME (so higher res the better, and it needs to play, MAME and all the consoles, etc....).
While I like the idea of going with widescreen LCD mounting it vertically, I don't like when things get stretched out...... so unless I can avoid that, it's not really an option.
I have been looking at a 21.3 inch Samsung LCD (4x3), but to be honest, lots of bucks and it only get me an extra 2 inches over the current monitor.
The cabinet is 22 inches wide.... it looks like a 25 inch monitor will sneak in there (at least width wise.  Depth may be a problem.
So, anyone have any suggestions on a some UXGA or SVGA 25 inch montors ?  LCD would be great because it would free up some room in the cabinet (which means I could get the sub in there).  CRT of course will look even better for gaming, so I'm open to both.   Let me know!
Also time to get a dedicated PC, but I think the monitor is going to impact what kind of PC I get cause there isn't much room in that cab, given how I have it set up... (it wastes a lot of space).
Thanks everyone.
Jim
Thanks.
Jim
theCoder
Re: PinMame cab, next phase (monitor suggestions ???)
« Reply #1 on: July 03, 2006, 08:13:56 pm »
I recently picked up a 21" NEC monitor 0n ebay for $95 delivered.  I'm planning on using it on (one of) my next project.
DefJam
« Reply #2 on: July 04, 2006, 12:47:44 am »
I'll keep an eye out for that as an option.
Also, I just measured the cab again...  it's exactly 23 inches wide....  which is is just shy of what I think I need for a 27 inch montior...  anyone know if I can squeeze one of those baby's in there ???
NightGod
« Reply #3 on: July 04, 2006, 06:05:08 am »
My 27" TV is about 25" wide in the shell. I would think that if you shelled the monitor, you could get a 27" in a 23" wide cab, but you likely wouldn't have alot of room to put a frame around it.
