Author Topic: Update- Video Issue- SEE PIC  (Read 3535 times)
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« on: June 15, 2006, 11:09:14 pm »
This pic is from my outrun cab, Just bought this game in non working condition last month with video issue. Any ideas.
The facts:
- New happ monitor installed- verified wiring is correct
- New switching power supply installed
- Removed 25vdc capacitor
- Removed ac filter
- Removed transformer
- Tested 5v to pcb
- Tests 12v to power amp board
- Tests 120v to fan
- Removed old fuse block
- Tried adjusting monitor/video controls
 Seems exactly the same with all these parts change, I will be receiving a power amp board (sound board) to swap but believe that the main pcb is no good. I have tried adjustin the monitor controls and eliminated the test/service switches. Also disconnected the sound board and the filter board with thesame issue with video.
How its wired: Until games works I have eliminated the on/off switch, Incoming 120v power connects to power supply(ps), monitor plugs into ps, from ps 1- 120v connect to fan, on the 9pin connectors which there are 2 connectors total-
9 pin connector described:
2 - 5vwires to pcb, 3-ground wires(2  from pcb - 1 from sound board) and 1-  -5v not used, 1-   12v to sound board, and another connector not used. Video plugged into pcb to monitor. Gas pedal/control panel/shaker motor/coin door/coin counter  are currently disconnected until game works.
PLease let me know as I am trying my best to locate a board and will not stop until I get one, thanks
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
grantspain
Re: Update- Video Issue- SEE PIC
« Reply #1 on: June 16, 2006, 07:49:41 am »
is that an auto range frequency monitor or do you need to set it on a plug or digital menu
Kevin Mullins
    • Me on Myspace
« Reply #2 on: June 16, 2006, 09:19:55 am »
Is there any game play at all ?
Does it play "blind" ? (without monitor)
Looks like a video signal issue for sure.
But kinda need an idea if gameplay is functioning at all.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 16, 2006, 11:24:40 am »
The facts:
- Removed ac filter
Why on earth did you take those out? The motor and shaker are very high current units and the old power supply was made to run those. The switcher you put in is not strong enough. No one should ever remove the AC line filter.
Remember this cabinet was originally supplied with a Nanao monitor (operating at 100 volts AC too) and the video harness was wired to Nanao's video input pinout!
« Last Edit: June 16, 2006, 11:26:31 am by Ken Layton »
kjoel0123
« Reply #4 on: June 16, 2006, 01:57:23 pm »
Its a Happ Vision Pro monitor.. There is no gameplay at all with/without monitor connected..
I removed the ac filter as the new supply can handle this.. thanss for the info Ken , what do I need to do to get the video to display correctly, I still have the old transformer , cap and line filter.  I had the same exact video issue with the old monitor, thanks
« Last Edit: June 16, 2006, 01:58:58 pm by kjoel0123 »
Kevin Mullins
    • Me on Myspace
« Reply #5 on: June 16, 2006, 02:11:30 pm »
No gameplay at all = non-working PCB.
Has nothing to do with the monitor until you have a working game board.
You should be able to coin it up and play even without a monitor.
Sound and everything should be working before worrying about the monitor.
Need to start with the PCB.
(I know....frustrating as all get out huh?)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: June 16, 2006, 03:19:50 pm »
Yeah, sorry to say but those bars look like a game board fault. Nothing to do with the monitor, although, taking into consideration what Ken said, maybe it is (but you would likely hear sound).
Garbage on the screen like that can be a sign of many things:
 - Too low voltage (or I suppose too high would be bad too)
 - broken or dirty connectors
 - broken traces on the board
 - broken "legs" on chips, capacitors, resistors, etc
 - burnt out /  damaged chips, capacitors, resistors, etc
BUT pay most attention to Ken Layton's input. He's the real expert (I just play one on tv).
« Last Edit: June 17, 2006, 11:04:14 pm by RayB »
NO MORE!!
kjoel0123
« Reply #7 on: June 16, 2006, 05:01:54 pm »
Thanks for the great tips, I am now 100% dedicated to getting a new board.
Fyi: I replaced the steering assembly with the much better/newer/smaller happ  model and had the outrun wheel custom machined to fit, works very nice, much better than the old sega piece of crap with a ton of gears...
I will post pics once I get it running, hopefully soon.
Ken I will leave the shaker motor and all other accessories disconnected until I am ready to wire it up, thanks for the tips
update tinight: Took pcb apart, found the pins that connect the 2 boards together crushed, straightened them out correctly, coneected the board, same thing, seems like this blew up the board....
« Last Edit: June 16, 2006, 08:37:41 pm by kjoel0123 »
SirPeale
  • Green Mountain Man
« Reply #8 on: June 16, 2006, 09:24:46 pm »
Since the pins were all bent, check the solder joints to see if any of them broke.
kjoel0123
« Reply #9 on: June 16, 2006, 10:06:13 pm »
 I will check it out and get back to ya
Update: Solder joints look good
« Last Edit: June 17, 2006, 12:58:40 pm by kjoel0123 »
