Author Topic: Different layouts for different emulaters in mamewah  (Read 1175 times)
wallywalt
  • Last login:December 20, 2007, 09:13:14 pm
« on: June 09, 2006, 07:45:49 pm »
I've read the wiki, but all i can do is get one layout working for all the different emulaters I use.  How can i get a different layout to display for each emulater i have?? Gonna read the wiki again, maybe i missed something.
Xelotath
  • Last login:December 18, 2010, 11:07:44 pm
    • My Destructoid Blog
Re: Different layouts for different emulaters in mamewah
« Reply #1 on: June 09, 2006, 08:10:32 pm »
Yes you can, all you have to do is rename it like the emulator. Like if you have a config file that is zsnes.ini then you name the layout zsnes.lay and then the images the layout use, zsnes-art.png. And, you put this layout in the same directory as the others. I think this info is in the docs. This is for version 1.61, maybe it's different in 1.62 but I don't know I can't get it to run.
wallywalt
« Reply #2 on: June 09, 2006, 09:22:36 pm »
That was easy enough, that wiki should be updated. thanks for the info.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #3 on: June 11, 2006, 01:32:39 pm »
We're lucky to have anything there in the first place.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
wallywalt
« Reply #4 on: June 11, 2006, 02:48:37 pm »
I agree, but its purpose is to help, and i think it could be a little more explanitory in the layout section.  I'm not bagging the wiki, its helped me a ton. I'm just making a suggestion.  :-\
