Author Topic: what do I need to do to hook up home stereo speakers to my PC?  (Read 2714 times)
walls83
  • beer is good
I  have some really nice tower speakers and I want to hook them up to my Jukebox PC what do I need?
Please act like I have no Idea what Im doing and kind of go into detail.
BobA
  • What Me Worry?
Re: what do I need to do to hook up home stereo speakers to my PC?
« Reply #1 on: April 02, 2006, 05:51:10 pm »
A cable to connect from the pc to an amplifier.  Wire to connect the speakers to the amp.   A power source for the amp if it does not have one built in.
walls83
  • beer is good
« Reply #2 on: April 02, 2006, 08:28:57 pm »
do you have a link to an Amp for an example(cheaper the better)   ;D
also can I hook my Reciever up to my pc?
like Run from my PC to my reciever to the speakers.
thanks
BobA
  • What Me Worry?
« Reply #3 on: April 02, 2006, 08:58:50 pm »
If you have a receiver just connect your PC to the aux  or line in input and you do not need an amp.
bleemus
  • Last login:September 01, 2016, 12:53:24 pm
  • Party Pengo in the house.
« Reply #4 on: April 07, 2006, 10:07:57 am »
If you already have a stereo receiver that you are willing to sacrifice to the jukebox, you can get something like this for your PC:
http://www.soundblaster.com/products/product.asp?category=1&subcategory=16&product=14191
Quality on the optical outputs on this would most likely be better quality than connecting RCA plugs from your PC to a receiver/amp.
All of this assumes that you don't already have a digital out on your sound card, if you do, then just run that to your receiver whichever way the sound card/receiver says you should.
Reality is overrated.
StephenH
« Reply #5 on: April 10, 2006, 03:35:18 am »
Basically, you need an amp capable of driving them.   It is good to note the type, wattage, and ohm rating, and find yourself a compatible amp.    Basically, you can connect your PC to any amp with line in.   Some amps may use an RCA type connector, and to connect a PC, you need a 1/8" to RCA adapter (or probably to two RCAs if your amp is stereo).
