Author Topic: Route Cab under CP?  (Read 5333 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
Route Cab under CP?
« on: February 11, 2006, 03:14:29 pm »
Hi all.. I've been searching and I can't get a clear picture on this. Wit the "Project Arcade" should I route the portions that the CP sits on back of and bottom?
Thanks again guys!
My old user name was marlborroman13, but I kicked the habit many years ago!
AtomSmasher
    • Atomic-Train
Re: Route Cab under CP?
« Reply #1 on: February 11, 2006, 04:46:38 pm »
I'm not really sure what you mean, but the only part of the CP I put t-molding on was the top piece, which I wrapped t-molding completely around.
AMDman13
« Reply #2 on: February 11, 2006, 05:37:11 pm »
Thanks for the reply AtomSmasher.
I'm talking about the 2 side panel's 12" ledges  (where the CP sits on) and the 6" piece that is directly behind where the CP sits. Do these both need routing?
AtomSmasher
    • Atomic-Train
« Reply #3 on: February 11, 2006, 09:02:31 pm »
Ah ok, I did route mine, but then I didn't put any t-molding there because its not needed.  So I'd say no, you don't need to route that, but it doesn't hurt anything if you do.
AMDman13
« Reply #4 on: February 11, 2006, 10:00:24 pm »
AtomSmasher... Thanks again. That's what I thought. Well I planned to route the whole thing before assemble, but I bought a 3/32" slot cutter and the T-molding I got from t-molding.com requires a 1/16".. I tried it on scrap wood and it fits, but just fall's right out! The book kept referring to a 3/32", so I thought I was golden. 12.00 for a new bit..(talk about getting nickel and dimed) Now I will start the assemble tommorow (baseplate with castors) Let the glue set for a day and maybe install 1 of the sides Mon night!! :)
