Author Topic: NEED HELP PLZ!!! : daphnex 096 wont load  (Read 3363 times)
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« on: February 06, 2006, 08:48:53 pm »
How do I get this work, daphnex 096?
I have Px HDD Loader V1.3 an it will not copy disc 1 of 10 to my hard drive.
It will copy then my xbox will freeze saying, refreshing game list.
Help plz.  Thx
« Last Edit: March 30, 2006, 03:00:31 pm by whatzcrackn »
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
Re: daphnex 096
« Reply #1 on: February 07, 2006, 12:13:26 pm »
check to make sure your paths are correct in the setup files.
And check the readme with daphnex, it should have all of that in there.
And lastly, if that doesn't help, do a search on the xbox-scene forums, there is some good info there.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
Re: daphnex 096
« Reply #2 on: February 07, 2006, 04:02:30 pm »
Use DVD2Xbox. It is much better than Px HDD Loader
I have troubles copying games once in a while with HDD Loader, but then I use DVD2Xbox and it will load them perfectly.
slycrel
  • Mmm... Portal.
Re: daphnex 096
« Reply #3 on: February 07, 2006, 06:23:02 pm »
Oh, and you need to use dvd2daph to rip the DVD on a PC and then put the mpegs on your xbox to use daphnex.  If you just rip the DVD then you'll have to use a dvd player to play the game.  Daphne (in any of it's ports) uses the files as if they were from the laserdisc, not the DVD.
Good luck.
whatzcrackn
Re: daphnex 096
« Reply #4 on: February 07, 2006, 06:49:59 pm »
thx!!
whatzcrackn
Re: daphnex 096
« Reply #5 on: March 23, 2006, 02:04:58 pm »
Getting errors when trying to load roms help!!  Any have a tutorial?
edit:
I guess I need the frame files?  Has anyone or is anyone running this on their xbox?
THX!!
« Last Edit: March 30, 2006, 12:18:26 pm by whatzcrackn »
whatzcrackn
Re: NEED PLZ!!! : daphnex 096 wont load
« Reply #6 on: March 30, 2006, 12:19:07 pm »
 :hissy:
I am sinking here,  can some help!
slycrel
  • Mmm... Portal.
« Reply #7 on: March 30, 2006, 01:18:19 pm »
Where did you get the mpegs?  The frame file should have been created at the time the mpegs were ripped from the DVD/laserdisc.  Do a search on the forums, people have posted other frame files in the past.
whatzcrackn
« Reply #8 on: March 30, 2006, 02:59:55 pm »
I bought a ten disc set and was told everything is on disc one.  but when the guy I have installing them cant find one single thing taling about framefiles. so he has read the read me file and still no luck with the installation.
I am being told Xbins-dev.nfo  has what I am looking for.
What  should the file(s) look like?  How do I install them?  Do you have it working?
slycrel
  • Mmm... Portal.
Re: NEED HELP PLZ!!! : daphnex 096 wont load
« Reply #9 on: March 31, 2006, 04:13:16 pm »
Check this thread for some more info on frame files:  http://forum.arcadecontrols.com/index.php?topic=19305.0
one guy pasted his frame file text in an actual post so you may be able to use that to attempt getting it working.
If you got a compilation, I would expect any laserdisc files to have a framefile included with them, especially for Dragon's Lair.  If I were you I'd look harder on the DVD's that were sent.  just because the mpegs are on disc 1 doesn't mean that the frame files are, you should still check the other discs for those.
Good luck.
whatzcrackn
« Reply #10 on: April 01, 2006, 03:08:58 am »
thx for your help slycrel!!!
whatzcrackn
« Reply #11 on: April 06, 2006, 11:07:21 am »
Does anybody have the framefiles?  I will owe you big time  :cheers:
