I have found transformers that do a range that includes 5V (for example, 3V-12V transformers), but all the ones that I found had selectors for the voltage that did not include 5V (i.e. you could switch from 3V to 4.5V to 6V, but there was no way to choose 5V).
Would it damage a Blaze Stand to run it as 4.5V or 6V?
I guess 5V is not a typical American device need? I live in Pittsburgh, PA.
in that case... good news for you. I feed my
BLAZE STAND wich have bigger IRLEDS than the standard stand, With just 1,5 volt and it does not affect my gameplay at all.
With 1,5 Volt you can feed your stand without any risk to fry it
![Cheesy :D](http://newforum.arcadecontrols.com/Smileys/default/cheesy.gif)
Also I powered it with 3 Volt and 4,5 Volts with the same results than 1,5 Volt.
Ah, I forgot to Ask you....Why don´t you feed it with a normal USB port??. You can do it.
Or else, If you sacrifice the Recoil, you can feed the stand with the same Lightgun
I feed the Stands of my PC with a PS2 port.... with a USB to PS2 adapter. It works too
