Author Topic: Power requirements for a Jamma test rig  (Read 1894 times)
Hurray Banana
  • Last login:October 18, 2016, 02:11:08 pm
  • My unique teaching style
« on: January 20, 2006, 10:15:01 am »
I'm going to build a jamma testing rig following the instructions on the cps2shock site.
http://cps2shock.retrogames.com/jamma.html
I've got an old AT power supply rated at 90W, will this be enough for a jamma testing rig?
Cheers Eric
TZ Pinball, PowerDrift upright, 4 vertical Mame cab and 8 way 2 player Mame cab
SirPeale
  • Green Mountain Man
Re: Power requirements for a Jamma test rig
« Reply #1 on: January 20, 2006, 07:36:21 pm »
Likely.  It depends on the board, of course, but it should run okay.
What is the amperage rating on it?
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 20, 2006, 07:50:07 pm »
Overall wattage isn't so important as how much current is put out on each voltage.
In general, most gameboards will be fine with these minimum power supply ratings:
+5 volts, 12 amps
+12 volts, 2 amps
-5 volts, 1 amp
Other voltages like -12 volts are not used on JAMMA system boards.
Hurray Banana
« Reply #3 on: January 21, 2006, 12:12:11 pm »
Thanks for the info Peale & Ken.
The PSU is at work I'll check it out on Monday.
Cheers Eric
