Author Topic: Voodoo3 only displaying in B&W, PLEASE Help!  (Read 1868 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« on: December 19, 2005, 02:24:15 am »
I'm installing a 3DFX VOODOO3 3000 w/S-Video into an older PC (P3 450mhz). I downloaded the latest video drivers (I think) for w98se. The driver name is: VooDoo3v3000-w9x-1[1].05.00.exe. Anyway, I loaded it and booted up the monitor just fine (display looked great!), but when I replaced the monitor with a brand new TV w/S-Video connection, the picture was Black&White and so poor that I could not read any of the desktop icons.
If anyone has advice, a good site, or better drivers.  I would REALLY appreciate your help fast!
I also tried the original drivers (on the CD) and sanother set of drivers I downloaded.  Monitor looks great, TV is still B&W.
MPTech
   Better living thru technology!   ;-)
StephenH
Re: Voodoo3 only displaying in B&W, PLEASE Help!
« Reply #1 on: December 19, 2005, 03:03:58 am »
Have you tried adjusting the color control on your TV?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #2 on: December 19, 2005, 08:20:41 am »
sounds like the TV is only getting the LUMA part of the signal from SVHS (Luma = Brightness / Chroma = Colour) I have had this in the past and I ended up having to splice the 2 pairs of cables in the Svhs lead together.
another possibility is that you have the wrong standard selected for the output (Pal / Ntsc) here in the uk we use Pal but cards always default to Ntsc resulting in a squashed image with no colour :(
please remember that you will NEVER get a TV picture to look as clear as a computer monitor, this is due to the resolution of a tv signal and the interlacing in use (you will notice it most with horizontal lines flickering)
MPTech
« Reply #3 on: December 19, 2005, 08:31:47 am »
I tried this on 3 different TVs and same results on all 3 (I think that rules out Color Control).  I also tried multiple output standards (NTSC, United States, and several others), no color, but some did cause the screen to roll! (very bad).  As for the resolution, I'm building 2 Arcades (with a friend) and he is using the same TV, but different PC / S-Video card and his looks MUCH BETTER, not as good as a monitor, but quite a bit better.
Any sit I can go to on the Voodoo3 cards?  (I Googled, but came up short).
Thanks again!
MPTech
menace
« Reply #4 on: December 19, 2005, 09:46:44 am »
I had the same problem on my gforce card--it was defaulting to composite out and I was using s-video--once i forced it to output s-video the color came back--don't know if that is even a possible scenario with your card but just thought i would throw it out there
MPTech
« Reply #5 on: December 19, 2005, 10:31:02 am »
Hmmmmmm, I tried the "Auto" selection and I tried manually forcing it to S-Video out.  I didn't see any other options.
Still looking for a resolution.
Thanks for the assitance, please keep them coming.
I NEED to get this fixed.
Santa doesn't deliver B&W video arcades!
MPTech
MPTech
« Reply #6 on: December 19, 2005, 10:34:09 am »
OK fallback plan:
  Assuming I can't get this resolved, what video cards currently available can I get that are PCI w/S-Video and are relatively inexpensive? (something I can pick up at Best-Buy, Circuit City, Comp-USA, etc.)
Thanks again
MPTech
Jess--
    • My Botched Cab
« Reply #7 on: December 19, 2005, 12:17:55 pm »
try splicing the leads together (svideo cables usually have 2 screened cables in the join the 2 center wires together)
or pick up an svideo to composite adaptor (svideo plug one end / phono socket the other)
MPTech
« Reply #8 on: December 19, 2005, 01:28:35 pm »
I'll try to pick up an adapter (S-Video to RCA plugs).
Meanwhile, I'm still open to how to fix this problem with the card.
MPTech
SirPeale
  • Green Mountain Man
« Reply #9 on: December 19, 2005, 11:19:31 pm »
It may not be the card; it may be the cable.
S-Video cables are notorious for being very fragile.  I benchtested a new TV a few months ago with my DVD player.  It was fine, so I put the TV in it's new home, and...B/W picture!  I was like, WTF.  Turns out I broke something in the cable.  Replaced it and all was well.
MPTech
« Reply #10 on: December 20, 2005, 01:36:57 am »
I tried 2 different cables, with the same result.
I didn't want to spend days trying to figure the stupid Voodoo card out so I bought a new ATI card for $59 tonite.  Installed it and it booted up the TV in color and looks great!!!
I'm DONE.
Anybody want to buy a POS Voodoo card?  I'm VERY disappointed!  I heard nothing but rave reviews about these cards.  Sure wasn't my experience.
MPTech
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #11 on: December 20, 2005, 04:18:24 am »
Maybe the physical output on the Voodo is broken?  Did you check the card for any damages or hairline cracks in the trace to the outout socket?
