Author Topic: Weird Ultimarc Behavior  (Read 1053 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: October 31, 2005, 10:56:34 am »
I was hooking up my modular player 2 controls over the weekend and was having this weird problem.
I have the Mini-PAC and was using the Ctrl-Alt-P notepad for configuration and tesing.  I have no shorts in the wiring and everything tested out okay from the joystick/button to the Mini-PAC.  But my Player 2 Joy Down wasn't working.
In any plan editor, the down registers as a 'g' which is my right, when I use the Ctrl-Alt-P testing mode, anytime I press down, nothing happens.  BUT when I let go, I appears to backspace/delete about a lines worth of characters.
I ended up connecting joy down to P2 Sw7 and just map that to 'f' which is down.  Everything works but its just a strange behavior.
Got to say is again.  Love the Ctrl-Alt-P.  Saved my life many a times.
GREAT JOB ANDY  ;)
Teamwork - A group of people running around doing what I say.
Lilwolf
Re: Weird Ultimarc Behavior
« Reply #1 on: October 31, 2005, 03:04:23 pm »
unplug from the board and wire it up directly and see if it works regular.
I'm guessing there is a wire problem.  But if you get it working from there, reprogram and try again.
MameJunkie
  • Eeeeeeeevil
« Reply #2 on: October 31, 2005, 03:47:52 pm »
