Author Topic: If you have MameWah working with a screensaver PLEASE READ  (Read 1164 times)
vader
  • Last login:January 19, 2025, 08:25:22 pm
  • I can't breathe in this thing !!
« on: October 30, 2005, 09:09:34 pm »
I have both a .scr and .mpg files of the movie I want to use ( arcade84 ).  I've tried every possible config in mamewah.ini and I'm having absolutely no luck.  If someone can please post their whole mamewah.ini file so I can compare, I would appreciate it very much.
Tim
headkaze
  • 0x2b|~0x2b?
Re: If you have MameWah working with a screensaver PLEASE READ
« Reply #1 on: October 30, 2005, 09:22:53 pm »
Do you need .scr? Won't MameWah just play the mpeg file and thats it?
vader
« Reply #2 on: October 30, 2005, 09:24:50 pm »
It will play both and have both, but niether are working, I'm sure I just have a wrong setting somewhere, but I'm braindead and can't find it
Tim
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: October 30, 2005, 11:50:49 pm »
Have you tried the full path to the mpeg file? Tried renaming it so there are no spacing in the path/filename?
« Reply #4 on: October 31, 2005, 05:30:19 am »
saver_type launch_scr
scr_file c:\saver\saver.scr
