Author Topic: ATI rage pro with Asus MB issue Help!  (Read 1591 times)
epic69
  • Last login:October 21, 2011, 04:21:03 pm
« on: September 06, 2005, 10:20:09 pm »
I seem to have a lockup issue with ArcadeOs and dMame using dos 7.0. I am trying to get this ATI rage pro video card to work with an Asus motherboard with Via chipset. every time I try and run ArcadeOs or Mame in dos it just locks up. I have searched the forums and found a few people with similiar issues. One suggested installing the Via 4 in 1 update driver. I have done that and still i cannot get this resolved. Any suggestions? Ideas? I am at teh end of my rope on this one.
epic69
Re: ATI rage pro with Asus MB issue Help!
« Reply #1 on: September 07, 2005, 01:56:41 pm »
Forgot to mention that i am using Svideo output to a 25" TV.
epic69
« Reply #2 on: September 13, 2005, 12:21:41 pm »
*bump* I still need some assistance on this issue, if anybody has some infomation. Thanks!
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: September 13, 2005, 12:23:19 pm »
The 4in1 driver is for windows only.
Are you running freedos 7.0?
Try switching to a windows 98 dos boot.
http://www.bootdisk.com
see if that helps at all.
Later,
dabone
epic69
« Reply #4 on: September 13, 2005, 03:59:37 pm »
Yes I am using Win 98 Dos. (dos 7.0) Are you aware of any drivers i can download to get this working correctly?
dabone
  • Time to work...
« Reply #5 on: September 13, 2005, 04:40:58 pm »
DOS DOES NOT REQUIRE DRIVERS FOR MOTHERBOARDS!
(Just sound and mouse drivers)
Are you running it from within windows??
These apps are made to run from dos only, not a dos command line window under windows.
To boot into straight dos mode edit your c:\msdos.sys file and change bootgui=0
(Also to disable the win98 splash screen add logo=0)
Later,
dabone
epic69
« Reply #6 on: September 13, 2005, 05:00:01 pm »
I am runnig dos and i have modified the msdos.sys.  I do not have a problem running arcadeos or dMame from within windows dos prompt.  I do get a lcokup when trying to run arcadeos or dmame from pure win98 Dos.
epic69
« Reply #7 on: September 13, 2005, 05:06:43 pm »
I should also add that the PC is curently using an Nvidia video card which does work fine in DOS. But the reason I am trying to use the ATI video card is that the TV out quality is much much better. as can be seen running arcadeos from within windows 98 dos command prompt.  I cannot stop using pure DOS because there are some games that simply have poor frame rates while runnigin in Win98. Also I do like the ease of shutdown in DOS.
epic69
« Reply #8 on: September 19, 2005, 05:15:51 pm »
I am still researching this issue and have not found a resolution. Can anybody suggest some possible avenues i can look at for this?
epic69
« Reply #9 on: October 26, 2005, 09:16:29 am »
I am still looking for a solution to this. Anybody have any ideas?  Thanks Everybody!
