Author Topic: GunCon2 Lightgun ????  (Read 2284 times)
rbarr110
  • Last login:August 31, 2025, 10:13:32 pm
  • I already built my own arcade controls!
« on: August 23, 2005, 08:02:15 pm »
OK - I have searched the threads and the net regarding using a guncon2 gun with mame on the pc.....however I am still confused.
From what I have found teh guncon 2 gun IS NOT yet compatible with a CRT monitor?
You HAVE TO use an arcade monitor or a television?
Is this correct?  If not can someone please help me find the information to use with a CRT monitor?
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
Re: GunCon2 Lightgun ????
« Reply #1 on: August 24, 2005, 08:37:50 am »
'Out of the box' this is correct. But.....
They can and do work on crt's if you use a device to halves the syncs of your vga signal. So you have a VGA signal going to the PC monitor as normal, but you take the syncs, process them, and feed them to the guns.
On the guncon2 forum I belive there is a circuit posted which you can build with cheap components that will do this. People have done this and reported success.
If you happen to own a Jpac, this already has a chip that does this exact process so you can use the output of that instead (although if you have a jpac you probably have an arcade monitor anyway).
I'm currently doing exactly the same myself, just need time to solder on connectors and I should be there.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: August 24, 2005, 10:31:27 am »
Barr, do you know what a CRT is? It means "Cathode Ray Tube". A TV uses a CRT. An arcade monitor uses a CRT. A PC monitor uses a CRT.
So maybe you'd like to re-word what you really mean...?
NO MORE!!
rbarr110
« Reply #3 on: August 24, 2005, 11:32:26 am »
OK, if we are being picky what I meant to say is....
"From what I have found teh guncon 2 gun IS NOT yet compatible with a CRT PC monitor?"
And yes I know what CRT means.
BTW, thanks for the useful reply Silver.  The only circuit I have seen says it is a conversion from a VGA signal for an arcade monitor, not for a PC CRT monitor.  Is it the same circuit?
« Last Edit: August 24, 2005, 11:57:15 am by rbarr110 »
rbarr110
« Reply #4 on: August 24, 2005, 12:17:58 pm »
Forgo one other question....
Will the light guns work through tinted plexi?
Acorn
  • Last login:February 12, 2006, 03:04:58 pm
  • Lightguns!
    • WinGun Driver
« Reply #5 on: August 24, 2005, 01:07:23 pm »
*possibly*
However, there will be some loss of performance, and at the very worst it will be nearly unusable. Different users have reported differently.
Read my faq at http://guncon.acornscity.com/faq.php , most of your questions are answered there (although it needs updated :) )
Get WinGun (Guncon 2 PC USB Driver) at http://www.guncon2driver.com
