Author Topic: J5 Viewer Question - Almost perfect  (Read 5789 times)
Tiger-Heli
    • Tiger-Heli
Re: J5 Viewer Question (Minwah, you're needed here!)
« Reply #40 on: August 30, 2005, 06:58:35 am »
For the most part, everything seems okay with the latest update except the pause issue still.  I'll see what I can find.
Are you using the latest versions that were released yesterday/today?  (If so, there is a sleep 250 value in two places in the script.  That MAY need to be adjusted for your particular hardware, although I haven't tested enough to know if adjustments are required or what they would be . . .)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: J5 Viewer Question - Almost perfect
« Reply #41 on: September 12, 2005, 12:40:01 am »
I just like this thread on the first page.
