Author Topic: dreamcast help  (Read 1501 times)
muell67
dreamcast help
« on: August 05, 2005, 10:20:39 pm »
Im trying to hook my dreamcast to my jamma cabinet and Im having a little trouble with the video. I have a naki vga box and I took it apart and going by this http://www.gamesx.com/avpinouts/dricas.htm i figure I need to cut wire 6. Ive read about alot of people getting wire 6 confused, it seems pretty straight forward to me. The large black wire is 1 (ground) then you count over to 6. The only problem I have with this is that I only have 15 wires not 16 like I was expecting. Is this correct?
My other question is with the old vga monitor cable I have. I cut one end off and now have 9 wires. The rgb are easy enought to distinquish but how do I know what the other wires do? I cant trace them back to the pin because of the large end on the cable.
niggenz
Re: dreamcast help
« Reply #1 on: August 06, 2005, 05:32:42 am »
If it is easier for you, you can just break the 6th pin at the AV connector.  Simply count to the 6th pin, prop it up with a finely pointed tool such as an exacto knife until it protudes from the grooves.  Get some needle nose pliers and turn and tug at it till it breaks.  You might need to cut some of the plastic off of the AV connector  housing to get in and get a clean break, but that isn't a big deal, it will still seat snug in the DC's AV port.  Just make sure you count correctly and from the correct side so that you have the right pin.  Otherwise it is bye bye VGA cable/box.
For the VGA breakout, you will need a multimeter to perform a continuity test to find H and V sync.  Here is the pin out:
http://www.gamesx.com/hwb/ca_9to15VGA.html
If you don't have a mulitmeter, you can buy a VGA to 5 bnc cable.  R,G,B,H sync, and V sync are all already color coded for you.  And the shielding from any of the wires can be used as ground.  This route is slightly more expensive as the VGA to 5 BNC cable cost anywhere from $7-$40 if you don't have one already.
