Author Topic: What does this mean?  (Read 2712 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
« on: July 19, 2005, 01:33:04 am »
ok im looking at computer speakers to buy and i found a 2.1 system, 2 speakers ans subwoofer, and it says they are 800 Watts PMPO   ok theres no way those little speakers are 800 watts right? maybe that pmpo thing means something? help me out, thanks
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
Chris
    • Chris's MAME Cabinet
Re: What does this mean?
« Reply #1 on: July 19, 2005, 01:55:09 am »
--Chris
joshbr7257
« Reply #2 on: July 19, 2005, 01:59:24 am »
heres the address, i actually want to get the speakers for an arcade cabinet im building, and ive spent way over my budget so im looking for some cheap speakers ::)
http://www.txmicro.com/
ok i cant directly link you to the page, but just scroll about 3/4 down till you see speakers and im looking at these:
 800 Watts Flatpanel .86' thin SPEAKERS +SUB
Chris
« Reply #3 on: July 19, 2005, 02:31:13 am »
Some searching around seems to indicate that these are 20-watt RMS speakers, probably 5W per channel for the sattelites plus 10W for the sub.  More than enough for a MAME cab, a bit underpowered for a jukebox.
--Chris
--Chris
joshbr7257
« Reply #4 on: July 19, 2005, 02:42:34 am »
wow thats not many watts, so are they even worth $12? there better than average computer speakers, right? the ones that come free with most computers., so if i were to listen to music with these speakers it would sound crapy?
Chris
« Reply #5 on: July 19, 2005, 11:23:31 am »
For cheap computer speakers, 20W is a lot of power; most speakers in that range are 10-15 watts or even less.
The cheap speakers in my cab were $20.00 any they're 4 watts per channel with a 6 watt subwoofer. (I selected them because the subwoofer would fit under the coin box.)
--Chris
joshbr7257
« Reply #6 on: July 19, 2005, 03:17:51 pm »
Chris
« Reply #7 on: July 19, 2005, 05:14:23 pm »
but you said you used car speakers with the sub woofer?, sorry im not sure but how do you hook up car speakers to a sub woofer? is it like regular speakers, do they use speaker wire?
Yes, as long as the impedance values match.  The sattelites on my speakers were 4 ohm, same as the car speakers that came with my otherwise gutted cab.  I just desoldered the wires from the satellites where they connected to the amplifier board (which was inside one of the speaker shells) and soldered in the longer speaker wires from the car speakers just below the marquee.
--Chris
--Chris
