Author Topic: I am in ArcadeVGA hell!!!  (Read 3697 times)
Ovalblue
  • Last login:November 18, 2014, 03:24:08 pm
« on: July 13, 2005, 12:03:57 am »
Im going nuts!  The only thing stopping me from playing my new arcade cabinet is the driver install for my Arcade VGA and getting the resolution down to 640x288(or what ever that low low setting is).
Here are the steps that I have taken...
Uninstalled all former ATI devices and drivers
Installed the Arcade VGA Card
COnnected computer to arcade monitor
Tried to install the driver... keep getting this message "This display driver is not compatible with the display adapter installed in your system"
I went to Ultimarcs message boards... found a link for the old driver (my card was purchased over a year ago)
I manually signed this driver to my display adapter
The lowest I can get my resolution is 640x480... so my arcade monitor is still not configured right.
What am I missing here folks?  ... i know i am a newbie but I think I have tried everything!  =(
FYI... my arcade monitor is just a generic 27" arcade monitor purchased from ebay so I cant get the screen to allign right until the resolution is down to 640x288 (i am getting the screen split in two)
Someone please help... I wanna play some games and see that my hardwork was worth all these headaches.
-Aki
Re: I am in ArcadeVGA hell!!!
« Reply #1 on: July 13, 2005, 05:14:43 am »
Not sure what OS you have, but the lowest resolution XP will show is 640x480.  To get lower you need to go into Display Properties > Settings > Advanced > Adapter > List All Modes.  You can then select any mode the video card supports.
Also, 640x480 should be displayed OK on an arcade monitor (if the driver is setup OK) as the ArcadeVGA just displays that mode interlaced (it will flicker a bit but look fine).
Ovalblue
« Reply #2 on: July 13, 2005, 12:39:09 pm »
My os is XP... I will give this a try when I get home tonight.
I am still confused as to why my monitor wont configure correctly... the best I get is a split screen.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: July 13, 2005, 01:07:48 pm »
does the card you are using have 2 vga ports?
The original vga card has one port at 15k and the other at standard vga outputs.
Later,
dabone
Ovalblue
« Reply #4 on: July 13, 2005, 01:42:08 pm »
It only has one VGA port and one S-Video port.
I purchased it from Ultimarc a year ago so I am not sure if its the old or new version.
Lilwolf
« Reply #5 on: July 13, 2005, 05:47:33 pm »
there are a ton of apps which can change the res for you.  A good one is quickres.  Its nice because it also has a command line so you can use it in a batch file.
Ovalblue
« Reply #6 on: July 13, 2005, 06:00:56 pm »
Well I finally got the driver installed... Thanks for your help fellas!
Unfortunatly I am still not 100% finished with my problems.
I have the resolution set to 640x480.
MrSaLTy
  • Last login:August 10, 2025, 05:07:28 pm
  • nabisco reject
« Reply #7 on: July 13, 2005, 06:26:20 pm »
Did you try fiddlin with the horizintal hold and see if you can center the picture? just a thought.
Ovalblue
« Reply #8 on: July 13, 2005, 06:27:26 pm »
yeah... but it only moves the screen about an inch or so
dabone
  • Time to work...
« Reply #9 on: July 13, 2005, 10:06:39 pm »
Ok, 1 port usually means a 9200 based card.
I would double check your wiring.
I had a problem with one like that, it turn out to be a bad horz sync.
Later,
dabone
Ovalblue
« Reply #10 on: July 16, 2005, 04:25:36 pm »
I double checked my Horizontal Sync connection and it has a good connection to the Breakout cable i purchased from ultimarc.  (The V and H syncs are connected together with my arcade monitor since they dont have separate connections)
Any other suggestions?
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #11 on: July 17, 2005, 01:00:44 am »
did you use the ATI driver removal tool?
Enjoying the fruits of technological obsolescence one game at a time...
crackersixx
  • Last login:November 10, 2005, 10:10:53 pm
« Reply #12 on: July 18, 2005, 03:18:26 pm »
are you using a jpac? I had the same issue because I didnt plug the usb->keyboard plug into the mobo from the jpac so it wasnt geting power.
Is there lights on the jpac?
Ovalblue
« Reply #13 on: July 18, 2005, 07:27:08 pm »
I did use the ATI removal tool.
I do not have a Jpac... why would I need one?
Honestly... I think I am going to give up.  Just try and sell my arcade monitor and ArcadeVGA and just connect a TV to my computer.
Thanks everyone for trying to help!
Hopefully I can get a standard TV to work.
-Aki
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #14 on: July 21, 2005, 11:56:08 pm »
Forget that!  Sell your monitor and spend the money on a 27" D9200!  you can get one refurbed usually for $350..thats only like $100 more than a good 27" TV and BELIEVE ME you won't regret it!  The AVGA and D9200 are awesome together...i actually have 3 AVGA and 3 D9200s now (2 of them are 33" though  ;D)
