Author Topic: Power Supply Load? - Peter Chou USP-11  (Read 1894 times)
kcdonahue
  • Last login:October 12, 2015, 05:54:21 pm
« on: July 07, 2005, 10:01:30 pm »
Hello All,
paigeoliver
  • Awesome face!
Re: Power Supply Load? - Peter Chou USP-11
« Reply #1 on: July 07, 2005, 10:23:39 pm »
Looks to me like you ALREADY removed it.
I DOUBT that powers the marquee light, I have yet to see a 12 volt marquee light.
Your coin door lamps (which might ALSO feed off the isolation transformer), can be run from your PC power supply.
Short story, you don't need it.
MonitorGuru
« Reply #2 on: July 08, 2005, 09:42:02 am »
Actually, most Midway MINI (cabaret) games used 12 volt marquee lights... a set of 4 to 6 incandescent light bulbs instead of a flourescent tube.
kcdonahue
« Reply #3 on: July 08, 2005, 10:56:55 am »
Thanks for the replies!
I'm not with the machine now, but all power for the cabinet passes through the powersupply.  A smaller 3 pin molex runs from the power supply directly to the isolation transformer to power the monitor. I will check to see if the marquee light  runs off of the isolation transformer or not, just in case it helps the marquee light is a small flouresent.
Would it be best to just remove the power supply and conncect a 3 prong(grounded) power cable with an inline switch to the isolation transformer?
KC
