Author Topic: New Bartop Cabinet Pics  (Read 6477 times)
jcrouse
    • CPViewer
« on: March 10, 2005, 11:10:29 pm »
First off, all the credit for this cabinet goes to bishmasterb for the concept. I did all the drawings in Autocad and machined the sides on a CNC milling machine. The drawings will be available if anyone interested. Drop me an email at the address on my website at http://home.comcast.net/~cpviewer . All the parts are doweled together for a good fitment (again thanks to bishmasterb's idea).
Enjoy,
John
*** Edit ***
The plans are available here: http://home.comcast.net/~cpviewer/pics_bartop.htm
*** End Edit ***
« Last Edit: March 13, 2005, 07:22:30 am by jcrouse »
jcrouse
    • CPViewer
Re: New Bartop Cabinet Pics
« Reply #1 on: March 10, 2005, 11:11:57 pm »
Another.
jcrouse
    • CPViewer
« Reply #2 on: March 10, 2005, 11:12:53 pm »
Last one.
John
Knievel
    • Knievel Kustoms
« Reply #3 on: March 10, 2005, 11:40:33 pm »
Hey John looks REALLY nice. I'm interested in seeing your plans. My rock'n'roll buddy wants something small for their tour bus. Looks like you went all out, is everything laminated...what size monitor?
GGKoul
  • Cheesecake Apprentice
« Reply #4 on: March 10, 2005, 11:47:06 pm »
Looks Sweet!!
mahuti
« Reply #5 on: March 11, 2005, 12:37:00 am »
Amazing use of space.
jcrouse
    • CPViewer
« Reply #6 on: March 11, 2005, 08:08:24 am »
Yes, black formica on the inside and of course yellow on the outside. I've tried painting before and failed miserably. The monitor is a 15" Wells Gardner D9100 running at 800x600. Send me an email to the address on my website at http://home.comcast.net/~cpviewer and I'll email you the cad drawing.
John
jcrouse
    • CPViewer
« Reply #7 on: March 11, 2005, 08:15:07 am »
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #8 on: March 11, 2005, 04:17:34 pm »
Really nice job!....I'm really thinkin' I need something like that for my office soon!
Good job on your art too!  ;D
MameMaster!  8)
Magnet_Eye
  • Last login:May 11, 2020, 09:26:19 pm
  • Feel the heat?
    • Web Hosting deals for BYOAC Users!
« Reply #9 on: March 12, 2005, 01:43:59 am »
looks nice man!
though i would have put in a balltop joy...
I offer discounted WEB HOSTING to BYOAC members! Only $2.49 a month for a FULL FEATURED account! www.cloud9media.com
Fig
  • Last login:January 25, 2026, 09:13:12 pm
  • (-_-)
« Reply #10 on: March 12, 2005, 11:18:56 pm »
jcrouse ,
Many thanks for the drawings
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #11 on: March 13, 2005, 12:36:56 am »
Any problems with air circulation/heat buildup?
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
jcrouse
    • CPViewer
« Reply #12 on: March 13, 2005, 12:54:20 am »
Your welcome.
None so far. I don't really expect any. I cut holes in the monitor tray and the fans in the top rear should pull everything out.
Enjoy,
John
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
« Reply #13 on: March 16, 2005, 10:06:38 am »
Very nice work, I had to run to my gameroom to make sure mine were still there!  :)
Good job.
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
jcrouse
    • CPViewer
« Reply #14 on: March 16, 2005, 10:11:52 am »
Bish,
     Thank you very much. As you know, it was totally your concept. I actually like the contours of your a little better. Yours seems a little less boxy than mine. Using an arcade monitor (the depth and bezel size) limited me somewhat.
John
bishmasterb
    • Bishopzone
« Reply #15 on: March 16, 2005, 06:50:55 pm »
Where did you find the yellow/black laminate? Mine are all painted, but I'd prefer the laminate. I've been hesitant to use laminate for fear of chipping during cutting. How did you get around that problem?
Thanks for the compliments. Of course mine is derivative of others as well, the main things I think I added to the design are placing the CP into the shell of the cabinet (most of the other one's had external CPs) and keeping the overall shape more in line with traditional full-size cabinets.
I've got some other ideas as well, but just no time to get them done!
jcrouse
    • CPViewer
« Reply #16 on: March 16, 2005, 07:43:35 pm »
The black laminate is Wilson Art - Black 1595:
http://www.wilsonart.com/laminate/consumer/products/viewitem.asp?idproduct=474&idCategory=40
and the Yellow is Pionite - SY914
http://pionitesamples.recol.biz/detail.aspx?id=4590
If you never used laminate your missing a real treat. I truly is easy (and fun) to work with and makes even a hack like myself look like a professional.
I cut the sides then applied the black inside. A router bit has straight flures and a ball bearing for a guide. It cuts the formica perfetly straight as the bearing rolls on the edge of the MDF. I then used a centerdrill (machine shop item) to drill all the holes for the dowels and starter holes for the screws. A centerdrill has straight flutes and will not grab at the formica and try and pull it from the MDF. After centerdrilling for the dowels I then used a 3/8 formica cutter to just spot drill (countersink) the formica down to the depth of the MDF. That way the dowels don't actually touch the formica, again risking the chance of pulling it or chipping it. It sounds like a lot but is really quite simple. After all this I then glue on the Yellow and route the edge.
I cut my sides on a CNC milling machine. I am getting ready to make a 1/2" think aluminum master side. That way I can cut them all in my garage by just clamping the plate on a piece of MDF and using a router. I am also going to put drill bushings in the aluminum plate for a drill template for the 1/4" dowel holes. This should make building the next couple a breeze. I want to make another with a verticval monitor. I figure with the template I will be able to make a set of sides in about 15 or 20 minutes. I may make some extras if anyones interested and offer them to people on the board for materials costs and shipping (just a thought). Anyone interested?
You can email me at the address on my website at http://home.comcast.net/~cpviewer . I'll help ya in any way I can.
be in touch,
John
« Last Edit: March 16, 2005, 08:07:15 pm by jcrouse »
redcoats
  • Last login:March 15, 2015, 04:04:56 pm
« Reply #17 on: March 16, 2005, 09:35:26 pm »
be in touch,
John
So if I had you make one for me could you just make it without all the componets like monitor, computer,marquee and joysticks? Just the bare cab? If so how much do you think that would cost me with shipping included. I would really love to have a small centipede or robotron. With basically the same color schemes as those?
GGKoul
« Reply #18 on: March 16, 2005, 10:10:16 pm »
I would be interested!!!
Truz
  • Last login:February 23, 2009, 12:03:01 pm
« Reply #19 on: March 17, 2005, 03:32:42 pm »
i would be extremely interested as well!
redcoats
« Reply #20 on: March 17, 2005, 04:21:46 pm »
Well looks like you have 3 of us interested. :) I might be interested in more than one though. I need to know if you can make more than just the yellow scheme?
« Last Edit: March 17, 2005, 05:23:06 pm by redcoats »
