Poll
What should I do with this cab?
MAME It
1 (3.6%)
Restore it to its former glory
11 (39.3%)
Trade it as to someone for a MAME cab
16 (57.1%)
Total Members Voted: 27
Author Topic: Is Missle Command a good cab for a newbie?  (Read 4499 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
Re: Is Missle Command a good cab for a newbie?
« Reply #40 on: February 26, 2005, 08:28:40 pm »
I'd say definately trade it off or resale it.  You can get a cheap mame cab if you look around more.  I have an empty Tempest cab you can have for free if you wanna come to Florida and pick it up  ;D
Good luck to ya!
Witchboard
« Reply #41 on: February 26, 2005, 10:10:27 pm »
picked her up and she is a beauty.. works great.... even had the original instructions taped in the inside
the trackball is huge at 3 in... could use a little bit of lube/wd40 ...
still has the state inspection stickers for 82-84.. artwork is pretty solid... i actually think it looks good with a little wear.. if it was too perfect, might look like a reproduction
3"?  If I recall isn't the trackball on Missile Command a 4"?  I may be wrong seeing as how I've never been lucky to get one.  ;)
j123vt_99
  • Last login:August 24, 2006, 09:41:12 am
« Reply #42 on: February 26, 2005, 11:54:17 pm »
i stand corrected.. 4 " is right
Pictures of my Missile Command  http://www.nimsu.com/mc/mc.html
Witchboard
« Reply #43 on: February 27, 2005, 12:05:14 am »
AHHHHHH!!!  I just read again.. DO NOT USE WD-40 for lubrication!  I use 3in1 oil.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #44 on: February 27, 2005, 01:39:42 am »
WD-40 is not a good lube choice.  Use real oil, 3-in1 or similar.  WD dries up and leaves sticky, dirty residue.
paigeoliver
  • Awesome face!
« Reply #45 on: February 27, 2005, 07:57:32 am »
Does the monitor have a good picture? If so then just clean up the cabinet really well and replace the trackball rollers and bearings and you will be pretty much finished.
j123vt_99
« Reply #46 on: February 27, 2005, 08:26:15 am »
monitor is near perfect... how do i replace the rollers and bearings?
also the marquee light is out... i'm willing to bet it's just a old bulb (could be the original)
