Author Topic: Nedd controller hacks for Dreamcast with detachable VMU slots  (Read 823 times)
Otraotaku
  • Last login:May 17, 2025, 05:38:18 am
  • トラビス
« on: February 19, 2005, 02:09:32 am »
Need Dreamcast Controler hacks, and with detachable VMUS slots... I want to put slots in my CP that correspond to the memory cards + show the Design... ^.^
Preferably in Analog control... but i will have to get a little more into that before I completly decide analog...  ;D
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
Re: Nedd controller hacks for Dreamcast with detachable VMU slots
« Reply #1 on: February 19, 2005, 12:36:14 pm »
If I read that right, you want to remove the VMU slots from the controller. You'd be much better off just trying to mount the bulk of the controller where you wakted the VMUs. Otherwise you'd have to desoler them and than solder tons of wires from the controllers to the slots.
Goz
  • KOTA
« Reply #2 on: February 19, 2005, 01:15:01 pm »
You do realize that the MGCD comes with a header for VMU slots right? What this means is that you can get a harness to plug into it that relocates the VMU just as you are describing.
-Goz
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #3 on: February 19, 2005, 09:36:37 pm »
ive done this on my dreamcast cab...
http://www.cosmicbreaks.com/arcade
its midway down
not too hard, rip apart 2 cheap memory cards and solder some ribbon cable on there.....
Otraotaku
  • トラビス
« Reply #4 on: February 20, 2005, 01:08:27 am »
I was planning on adding the little VMU w/screen in the middle of my CP flat. with a plexi cover... that way it will digitaly display the logo or Whatever is on the VMU's screen  ;D
