Author Topic: Arcade controls for 1st player...and standard PC joystick for 2nd one ?  (Read 3385 times)
Jeehemdee
Please excuse my ignorance...here is my question
I'm on a 1 player cabinet, running advmame(advmenu) and I wonder where (and how) I can set up it to accept  "player 2" connected with a standard PC joystick on the serial interface... ???
Thanks very much
Lilwolf
Re:Arcade controls for 1st player...and standard PC joystick for 2nd one ?
« Reply #1 on: October 23, 2002, 01:38:39 pm »
You can, but why?  Do you want to make sure that one of you has an advantage?
Here, My cabinet and I always play player one... and heres your thumb pad...
the price of an extra joystick and extra buttons is VERY small compared to everything else in a cabinet.  Doesn't seem like the place to save a few pennies...  look at www.videoconnect.com for cheap buttons and joysticks... (best place when I last bought items... plus have some weird items)
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: October 23, 2002, 03:09:11 pm »
That could be a cool idea for Bartop cabinets, to allow for multiplayer games. It might not be too bad , esp. for cooperative games -- Gauntlet, for example. It might not be too bad for fighting games, if the game pad has macros...
Might also be a decent solution for occasional 4 player play on standard sized 2 player cabs...
Bob
Jeehemdee
« Reply #3 on: October 23, 2002, 05:37:50 pm »
That's exactly the case, my cabinet has only 1 built in controller (and I don't want, neither need to change it).
I just would like (as told by Neuromancer) to occasionaly add a second player....(all that in advancemame/menu)
so thanks for any kind help ;-)
Lilwolf
« Reply #4 on: October 23, 2002, 06:56:44 pm »
Yes... just setup your player2 buttons to the joystick or whatever.
I've seen this on bartop tables.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: October 24, 2002, 07:06:15 am »
Thanks very much
Not sure where I'm supposed to go with this, as you left it pretty vague and wide open.
First off, standard PC joysticks don't connect on a serial interface.  They use a DB15 gameport connection.  If you don't have a gameport, you need to add a soundcard for around $10.  If your gameport is used for your current player 1 controls, I would recommend getting an I-PAC for $40 and re-wiring.
Assuming you have a gameport, you can get a 6-foot joystick extension cable (check www.pricewatch.com or locally, if there's a www.microcenter.com near you) and route it to the front of your cab (side of your cab) for a place to plug the joystick in.
The MAME default is to have the joystick control Player 1 so you need to remap it to Player 2 and away from Player 1.  For MAME 0.60 and up, this is easiest using controller.ini files, see  http://www.fraggersxtreme.com/arcadepanels/faq.htm, about half way down the page for info on setting these up.
That should get you there!  Having said that, this is NOT the way I would go.  Consider the following.
Your cab probably already uses an I-PAC or some kind of keyboard encoder with unused inputs for Player 2 available.
From here, you can route half of a cut DB15 (joystick), Mini DB15 (VGA monitor) or DB25 (RS-232, cheaper) extension cable to a port on the panel, similar to what I recommend for the joystick connection.
The other half goes to REAL arcade controls.  You can get a Happ joystick and 6 buttons from www.therealbobroberts.com for under $20 or you can get an off-brand joystick and 10 black buttons from http://xgaming.net/Merchant2/merchant.mv?Screen=CTGY&Store_Code=XOS&Category_Code=exp for $12.
Now you need a 12-inch wide 1x6 to mount the buttons and joystick to.
The tricky part is figuring out how to attach this to your cab so it is removable, sturdy and Player 2 can see the screen.  One idea is to mount brackets to the front or side of your cab for the panel to attach to.  Another would be making a "podium" out of the controls so it is free-standing and can be brought out/put away as needed.  Or you could just add 3-inch tall 1x6's under each side for a desktop (bartop) style controller.
Hope this helps!!!
Jeehemdee
« Reply #6 on: October 24, 2002, 08:38:52 am »
Thanks very much for your reply
This is exactly what I want (and have done)
The only reference on "controller.ini" that I can found on this page is "0.60 - Controller.ini files added.  Provides ability to edit a text file to change key assignments." but it doesn't apply to Advanceame ? How do I do specificaly in AdvanceMame ? Thanks
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: October 24, 2002, 08:58:04 am »
[The only reference on "controller.ini" that I can found on this page is "0.60 - Controller.ini files added.  Provides ability to edit a text file to change key assignments." but it doesn't apply to Advanceame ? How do I do specificaly in AdvanceMame ? Thanks
You wanted to go further down the page to the question worded "Can you explain what Ctrlr.ini files are and what are the advantages of using them?"
I can see that I need to split this into MAME FAQ's, Controller FAQ's, etc.  Oh well, another project for a different millenium.
I know nothing about AdvanceMAME.  The last time I used it, it was basically just a mod of the official MAME source to allow for custom video resolutions, but I think it has evolved significantly since then.
If it doesn't use ctlr.ini files, it may use the standard user interface (Tab Key - Inputs All Games).  Otherwise, I don't know what to tell you.
Sorry.
