Author Topic: automatically running arcadeos (help quik!)  (Read 2479 times)
mey
  • Last login:January 12, 2006, 05:54:01 pm
« on: November 18, 2004, 07:31:10 pm »
ok heres my problem
ive tried every way to get arcadeos to run nesticle thru dos. for some reason it just wont work i have to run it thru windows (3.1) can someone tell me the autoexec.bat command to automatically run arcadeos thru windows?
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re:automatically running arcadeos (help quik!)
« Reply #1 on: November 18, 2004, 07:32:30 pm »
 I believe its actully the boot.ini file...there should be an entry called Shell...this will be set to explorer.exe, just change this to arcadeos and it will boot directly to arcadeos instead of windows.
mey
« Reply #2 on: November 18, 2004, 07:47:49 pm »
i cant find nething called boot.ini
but i dont think you understand what i mean
in the autoexec.bat file i made the final command
cd c:\arcadeos
arcadeos.exe
and it went into arcadeos fine but it wont run nesticle right but when i go into windows 3.1 and open arcadeos there it works fine.
so what i need to do is open windows then open arcadeos thru that. but i want it to do it automatically.
thanks in advance
mey
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #3 on: November 18, 2004, 09:15:25 pm »
It's actually system.ini under c:\windows, not boot.ini where you change explorer.exe to wherever your arcadeos.exe is at.  That's under Win98 though.  I am not sure about win3.1.  You should also be able to put it in the startup folder so it boots when windows boots.
DaemonCollector
« Reply #4 on: November 18, 2004, 10:10:37 pm »
Hmm...sorry, I did misunderstand what you wehre trying to do...I havn't tried to run anything in pure dos in a while, maybe you need Dos4gw? I know nesticle uses it and win 3.1 prob autoloads it...ill attach it and put it in the same directory as nesticle...then run nesticle through arcadeOS like you've been tryin
