Author Topic: Marquee retaining methods - What do you use?  (Read 1711 times)
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« on: November 09, 2004, 03:34:28 pm »
I tried getting hold of the Happ Marquee retainer, but it was pretty expensive to get it from Happ UK (about
NoOne=NBA=
Re:Marquee retaining methods - What do you use?
« Reply #1 on: November 09, 2004, 06:53:45 pm »
I used cabinet magnets to hold the marquee to the cabinet, and used some 3/4" x 1/4" hemlock shoe molding to trim it out on the front.
I think the entire 8' piece of trim was a few bucks at Home Depot.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: November 09, 2004, 07:03:14 pm »
Do a Search man... this topic has been covered in depth.
Search for "marquee retainer alternative" (as a phrase) in the Main Forum.
NO MORE!!
KrawDaddy
  • Last login:February 19, 2007, 06:37:04 pm
  • I am a LOSER
« Reply #3 on: November 09, 2004, 08:58:49 pm »
Try that carpet cove moulding I used on the Gold Mine
P.S. Dont mind RayB.....he spends every waking moment trying to disrupt our harmony.  ::)
« Last Edit: November 09, 2004, 09:00:24 pm by KrawDaddy »
All I ask is that my routers obey me as though they would the word of GOD!
ras2a
    • Nolij
« Reply #4 on: November 10, 2004, 05:43:29 am »
Cool ideas fella's.  Sorry RayB, I did do a search (usually do) but didn't use the term you'd suggested. ..can understand it's just cluttiering up the forum with dupe threads blah blah.
Thanks for the info
ras2a
    • Nolij
« Reply #5 on: November 10, 2004, 05:47:31 am »
Wow that sounds ace.  I wouldn't know where to get hold of that over here in the UK.  We have places like 'Homebase' etc which are usually crap at stocking stuff like - lol.  Will ask around.  I'm a little confused as to how you used these?  Did you have some sort of metal slats 'behind' the marquee and then the magnets on top with marquee sandwhiched in middle?
cheers mate
paigeoliver
  • Awesome face!
« Reply #6 on: November 10, 2004, 06:19:39 am »
Happy 1000th post RayB, that one was number 1000
RayB
  • There's my post
    • RayB.com
« Reply #7 on: November 10, 2004, 09:35:03 am »
WOOOO!!
NO MORE!!
NoOne=NBA=
« Reply #8 on: November 10, 2004, 09:42:11 am »
You can make your own by thinly slicing a piece of 1x lumber, and then sanding the top two edges slightly to round them.
That's all that piece really is.
The hemlock is nice because it's more flexible than some other woods, so doesn't split as easy.
As far as using the magnets goes, they are standard ones you'd see on a bathroom cabinet, stereo cabinet, etc...
I screwed the magnet part, one on each side of the cabinet, and glued the metal part to the back of the lexan.
The nice thing is that I don't have to do any unscrewing etc... to access the marquee light.
I can just pull that panel off of there.
ras2a
    • Nolij
« Reply #9 on: November 10, 2004, 11:31:25 am »
Sounds like a good idea...I may give it a whirl if I can't find anything else suitable.  Thanks for the input everyone.
somunny
  • Is it hot in here?
« Reply #10 on: November 10, 2004, 12:19:54 pm »
Hey Ras,
I found some great carpet molding at Home Depot.  And since your cabinet has the same basic design as mine, I think it would work great for you.  Nice and clean, *especially* on the bottom lip.  That angle on the UAII had me a little worried.  I'll get a picture of it up.
btw  What's the width of your cab?
Coop
somunny
« Reply #11 on: November 10, 2004, 12:45:06 pm »
Okay, here we go:
The piece on the left is for the to and works like Happ's retainer.  The screws go into the top of the cab, so you don't see them.  The piece on the right is for the bottom.  I was worried that with the angle on the speaker panel, I'd have to bend something to fit.
This piece, however, attaches right to the exposed edge and becomes a track for the marquee plexi to fit in.  The slot is 1/4" wide.
Once the moldong is attached and the marquee is inserted the look is super clean.
Hope this helps,
Coop
You're in the UK, right?  If you run out of ideas (and around here, that's near impossible), let me know and I can send you some from my left over pieces.
ras2a
    • Nolij
« Reply #12 on: November 10, 2004, 07:07:32 pm »
Okay, here we go:
Hope this helps,
Coop
Hey that's wicked.  I can how the top piece fits on, that's very straightforward.  But I still can't envisage how the bottom strip fits on.  I've sent you a private message!
EDIT: Doh, I was being extremely dim....ok I think this is how you mean - tell me if I'm right >>>
again, check your private message concerning you're offer!
cheers mate
- ras2a -
« Last Edit: November 10, 2004, 07:18:35 pm by ras2a »
somunny
« Reply #13 on: November 10, 2004, 09:14:53 pm »
Precisely!  Nice drawing, by the way.
I just used some very small nails to hold it on the edge.
They definitely need to be painted though, as the finishes of the pieces don't match very well.
Coop
