Author Topic: ArcadeOS and AdvMame, '-monitor' option  (Read 1893 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: August 30, 2004, 04:26:33 pm »
Using ArcadeOS and AdvMame, when I run a game (or try) I get an error about
"unknown option '-monitor' and the game never starts.  This appears to be
this option in ArcadeOS.cfg;
#Options passed to MAME for NTSC/Arcade monitor mode
arcmodeopt=-monitor arcade
I think it is sent because I have this option set to one;
#Selects video output type:
#0 = Standard VGA Output
#1 = Arcade Monitor / NTSC Output
#2 = PAL TV Output
#DO NOT SET TO 0 IF YOUR PC IS CONNECTED TO AN ARCADE MONITOR/TV
incabinet=1
I have to do so since I am running an arcade monitor
Does anyone know how to supress the '-monitor arcade' option from being
passed to advmame?  I tried commenting the line in the config as well as
deleting it, but it appears ArcadeOS recreates it each time.
Thanks, James
SirPeale
  • Green Mountain Man
Re:ArcadeOS and AdvMame, '-monitor' option
« Reply #1 on: August 30, 2004, 07:59:22 pm »
Comment out the first statement.  I believe it's different for AdvMAME (why they couldn't use the stock stuf, I dunno).  Don't know what the option is, but it should be in the docs.
vettetek
  • Last login:October 05, 2025, 10:53:53 pm
« Reply #2 on: August 30, 2004, 08:28:09 pm »
Im assuming you already ran the advcfg and advv programs to set up the monitor? I believe I was getting the same problem before I did that.
Hope that helps.
~V
RetroJames
« Reply #3 on: August 30, 2004, 09:05:58 pm »
Tried commenting it out, it just recreates it everytime I run ArcadeOS...
RetroJames
« Reply #4 on: August 30, 2004, 09:07:04 pm »
Hope that helps.
~V
I don't think I ran advv, I will try that
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 09:58:56 pm
« Reply #5 on: August 31, 2004, 05:47:47 pm »
advmame is the one giving that error. There is no Advmame gamename -monitor arcade
That will not work.
Free VGA Breakout Cable
RetroJames
« Reply #6 on: August 31, 2004, 05:49:57 pm »
That will not work.
I figured that, the key is how to tell ArcadeOS NOT to send the option.
Thenasty
« Reply #7 on: August 31, 2004, 06:08:55 pm »
try ot fake it.
Instead of you putting
-monitor arcade
put
-startuptime 5
Maybe that will work if ArcadeOS don't know the difference.
SirPeale
« Reply #8 on: August 31, 2004, 07:18:00 pm »
Or you could ditch AdvMAME and go with regular DOS Mame.
RetroJames
« Reply #9 on: August 31, 2004, 07:26:58 pm »
Already been there, I could not get the video control I needed.  Advmame has resolved those issues.  I may go to advmenu.
