Author Topic: Is the wg d9200 worth the trouble?  (Read 1866 times)
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
« on: August 23, 2004, 06:55:27 pm »
I was thinking about buying a 27" wells gardner d9200 but I have heard reports of it failing and such.  Is it worth it to go with this monitor or do you think I should try to find an altrenative multisync monitor?  also, does the d9200 display 800x600?  I have heard that it does.  opinions please.
« Last Edit: August 23, 2004, 06:58:21 pm by shadowdrak »
whammoed
  • Last login:Yesterday at 11:22:30 am
  • Crack don't smoke itself
    • NiceMite
Re:Is the wg d9200 worth the trouble?
« Reply #1 on: August 23, 2004, 08:10:41 pm »
Well, in my opinion it is worth it, but I haven't had any trouble with mine.  Kevin at retroblast will be reviewing another multisync soon so if you can hold off a little while we will have an idea if there is a good alternative.  The newer d9200s will do 800x600 though they do not advertise it because it will not do it at 60hz vertical refresh only 54hz according to one of their techs.
bguss1
  • Last login:August 27, 2004, 02:22:36 am
« Reply #2 on: August 26, 2004, 11:51:30 am »
I love my 33" D9200 monitor.  Paired with AdvMAME and you have an arcade perfect experience in every sense of the term.   This pairing will allow you to run the exact arcade original resolutions and refresh rates for 99% of the games emulated in MAME.
See my MEGA arcade cab at:
http://gussnews.com/gallery/thumbnails.php?album=4
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #3 on: August 26, 2004, 02:27:29 pm »
I have an older D9200 running at 800x600 at 60Hz, and its a great monitor for arcades!  I had a few issues setting it up, but most were because I didn't know what I was doing.  I highly recommend this monitor to anyone.  WG is great with tech support as well if you have problems with yours.
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #4 on: August 27, 2004, 07:32:27 am »
The WG9200 is a great monitor I've had two of them without any major problems.
Gary
